Axiom 49 not recognized when I upgraded to PT 8.0.3
I was using my Axiom 49 with PT 8.0.1 fine. Over the weekend, I upgraded to PT 8.0.3 - and now, PT does not recognize my M-Audio Axiom 49. I've looked for something to uninstall / reinstall - but am not sure if that is the right path. Help! Thanks |
Re: Axiom 49 not recognized when I upgraded to PT 8.0.3
try going to
setup > peripharals > machine control > tick the slave box then go to midi controllers tab and see if you can select the keyboard in the 3 drop down menus Hope this helps |
Does this possibly apply?
http://avid.custkb.com/avid/app/self...+pro+pro+tools Do you see the Axiom Pro in Audio MIDI Setup? Is it greyed out? |
The slave box is checked.
The Axiom does appear in the midi drop down menu - so, I don't believe that is the issue. I have the Axiom 49 pluged into my pc through a USB connection (no MIDI connection through my 003 rack). Again, in PT 8.0.1, this worked fine. When I look at the midi controllers tab, the Axiom 49 is listed. If I pick it from the drop down menu, it asks me to pick a 'receive from' field - - where it shows the MIDI input from my 003 rack. I'm guessing that means it is expecting me to connect my Axiom through the MIDI port in my rack 003?? The reason I am questioning this is because it was working through the USB connection with the earlier version. Also, the Guitar Center kid said that it should work through the USB (and he's always right ). I also know that the Axiom is getting power from the USB . . . . Still confused & still not working! Thanks!! |
Hmmm strange - i use that version of protools and the same controller and have no problems
Maybe try reinstalling the drivers for the controller and see if it sorts itself out Failing that, i am clueless! |
I uninstalled / reinstalled everything & it is now working.
I'm sure this is related to the PT upgrade . . . but, I'm glad it's working again. Thanks for the suggestions. |
PT 10HD upgraded > but 192 not recognized | owenpop | macOS | 3 | 07-31-2012 04:51 PM |
Just Upgraded to Strike 1.5, but Authorization not Recognized | mix house la | macOS | 1 | 01-22-2012 02:29 PM |
Axiom Pro 49 and Axiom 61, Prepheral issue? | udhoshi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2011 03:45 PM |
Ok I upgraded... | Justin1524 | Pro Tools TDM Systems (Mac) | 0 | 11-10-2010 10:04 AM |
M-Audio Axiom 49 not recognized by PT 8.0.3 | sambeau | Pro Tools M-Powered (Win) | 4 | 03-18-2010 12:06 PM |
