right click select whole clip when trying to cut it
I know I can just press b but my work flow
is point to the area in the clip right click and cut when I right click it selects the whole clip grrrrr I know its something I'm missing and it simple just can get it and its frustrating win10 prot 12.8
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram |
Re: right click select whole clip when trying to cut it
Just my 2 cents; you're doing it the hard way instead of the easy way(drop the cursor and hit B is about the easiest edit done in PT)
Re: right click selects whole clip when trying to cut it
I don't know why when I right click it selects wht whole clip. It must be in options or something I cant find it but it change after upgrading from 12 to 12.8 help! I drop the cursor right click then cut..... i just want to do that... anyone?
You could try right-clicking and then "separate".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Make sure you have activated and know how to use the smart selection tool.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Maybe its time for a mouse/trackball with some extra buttons?
yes same here.....He should disable the multi tool. Just leaving the cursor active. imho
If I could do that then I wouldn't have to post this
when cursor is on the cut I right click separate is grayed out and the whole clips gets selected I don't get a chance to use separate in the pull down I'm missing something to uncheck in the prefs or the tools
What instrument are you holding? There are times when I track guitar (I'm also playing) and when I stop I need to make edits. This is where having a strap on the guitar (and using it) is a necessity. I can let go of the guitar and do what I need to do in PT even using both hands if necessary. Only downside is banging the headstock into the desk every once in a while If you're playing a sax get a neck strap. Now if you're trying to do an Ian Anderson thing you have to put the flute down. |
If you go on the position and click and then right-click, it should work. If you go on the position and click , but move the cursor away from the vicinity of the position and then right-click, it cannot work.
Keyboard Shortcut to Select the Next Clip in Clip List | TomMxEdit | Pro Tools 12 | 1 | 02-27-2017 11:52 AM |
select next clip in timeline (on all tracks) | johannes1 | Pro Tools 10 | 3 | 07-07-2015 09:48 AM |
How do I select multiple regions in the clip list? | Moviesound | Post - Surround - Video | 5 | 08-25-2012 05:31 AM |
How select a clip with Artist Control? | John Fishback | Artist Series | 4 | 05-21-2012 09:23 AM |
grabber doesn´t select clip with fades | Frank Kruse | Post - Surround - Video | 0 | 07-14-2005 08:44 AM |
