Old 10-12-2020, 01:20 PM
Tay Tay is offline
Default MIDI keyboard problems? Korg D1 Concert
Hey guys,
I have downloaded the driver I need for Korg D1 Concert, it has midi option and also Aux option within the keyboard.
But I can't seem to get this working, have been trying for the whole of this evening, watching different youtube videos to go into the midi studio and adding it as an instrument, still no signal is being received.
any help is greatly appreciated.
Taylor
Old 10-12-2020, 01:24 PM
Tay Tay is offline
Default Re: MIDI keyboard problems? Korg D1 Concert
Processor: Intel(R) Core(TM) i7-3840QM CPU @ 2.80GHz 2.80 GHz
Memory: 32.0GB
System type: 64-bit Operating System, x64-based processor
WINDOWS 10
Old 10-13-2020, 02:42 PM
Is the keyboard connected via USB?
Have you installed the Windows driver for the keyboard?
Have you set it up in Midi Studio(specifically, the Input Port which probably is something like Korg D1 on USB[Emulated]
If all that is in place, Create a stereo instrument track, insert MiniGrand in the top-most slot(Slot A) and hit the Record button on the track. That SHOULD send midi and trigger the plugin from the keyboard.
Old 10-14-2020, 04:50 AM
Tay Tay is offline
Thanks, although the keyboard has MIDI input/ouput. I cannot find the exact model drivers anywhere?
Old 10-15-2020, 10:20 AM
Drivers would only be required if you connect via USB(directly to the computer). How is the keyboard connected to the computer? We are still missing important details
Old 10-15-2020, 12:49 PM
Tay Tay is offline
AH ok! sorry yeah it is connected with USB, I have bought a midi cable converter by m-audio. so if i don't have the drivers the keyboard cant play USB?
Old 10-15-2020, 02:01 PM
junkgear's Avatar
junkgear junkgear is offline
Your M-Audio device will be your MIDI interface and that is what you will see as the MIDI device. In PT, you should be able to just add an Instrument track to your session and load up a virtual instrument on that track. Then press the record enable on the instrument track you just added and you should be able to hear it when you play something on your Korg.
Pressing record enable routes incoming MIDI to that track. If your audio outputs are set up correctly, then like I said, you should hear something.
Will K
System Details
Old 10-15-2020, 02:19 PM
Tay Tay is offline
thanks will try out
Old 10-15-2020, 02:21 PM
Tay Tay is offline
Solved, thanks a lot
Old 10-16-2020, 12:55 PM
Tay Tay is offline
Hi again, the Mini Grand seems to be working with what you're saying, however when I insert Xpand the same way, there is no signal when I am pressing the piano keys ? is there any reason as to why ? very confused thanks !
Need help with Korg Taktile 49 USB midi Keyboard prodigy_ed macOS 0 12-07-2014 09:34 PM
Problems recording midi (Korg SP-250) RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-14-2010 11:18 AM
HELP!!! KORG TRITONLE/001 MIDI PROBLEMS philipo MIDI 2 11-07-2002 12:57 PM
Korg Oasys Midi Problems rseely MIDI 10 05-19-2001 08:39 AM
MIDI with Korg keyboard Taylor1725 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-24-2000 06:52 PM
