Deleting playlists in grouped tracks
Hello,
I have a session with 14 tracks of drums that are grouped. When doing recording, the drummer did multiple takes of the song. There are about 25 playlists in this particular session, and when i put the drum tracks in playlist view, Pro Tools becomes so laggy it's practically unusable. I am assuming it's because I am viewing 25 playlists of 14 tracks each (so, 350 "tracks" at once just for drums.) There are plenty of playlists that are not needed, but even when tracks are grouped, if I delete a playlist from one track (e.g. Snare.19), it does not delete the equivalent playlists on the other tracks (ie. Kick.19, Hats.19, etc.) Any way to either quickly delete the unneeded playlists in total or to speed up my session while in playlist view? Thanks! Last edited by secutanudu; 01-16-2019 at 03:39 PM. |
Re: Deleting playlists in grouped tracks
In the track head there should be blue boxes indicating that the track has playlists, click on one of them and select delete unused, then it will show a box with all the playlists on the session, you just have to remember the name of the ones you want to delete. This will delete the playlists but the audio will remain in the session folder
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
That is what I ended up doing. However, it would be really nice if I could select one playlist from a bunch of grouped tracks and delete all of the link playlists in one click instead of having to click everyone individually. Thanks for responding.
Sent from my iPhone using Tapatalk |
Playlist management has a long way to go - if you've got 60 tracks of orch with 20 playlists and you need to delete playlists 2-11 you'll be there all day trying to sort through the "delete unused playlists" dialog.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Playlists falling out of sync with grouped tracks | someone | Pro Tools 12 | 13 | 10-22-2017 11:17 AM |
Playlists Grouped Between Tracks? | anackman | Pro Tools 12 | 4 | 08-26-2015 10:38 AM |
bug report-- solo playlists among grouped tracks only works if mix group is selected | Gems Records | Pro Tools 11 | 4 | 12-26-2013 09:21 AM |
Grouped playlists problems... | Drum | Pro Tools TDM Systems (Win) | 6 | 02-11-2011 10:09 AM |
Grouped tracks changing playlists | tonicjeff | Pro Tools TDM Systems (Mac) | 0 | 09-17-2009 04:25 PM |
