Old 11-08-2018, 02:04 PM
belasoul belasoul is offline
Default 3rd Monitor Choice / Audio for Picture
ATM i use a Mac Pro 6.1 with a D-300/12core/64Ram and two thunderbolt displays for mostly soundediting.
I would like to upgrade the setup and get a third monitor to showing the picture. I tested a directly hdmi connected panasonic tv which seemed to work quite smoothly, even though i'm using a feature length h.264 (in full quality mode).
What would you recommend from your long term experience, when it comes performance in bigger sessions and video stability. Would you recommend an external video hardware right away or would stay with the mentioned setup for now? If yes, what specific video hardware would suggest combined with a trashcan?
Also are there any specific TVs/Monitors which can be recommended? I'm thinking about getting a Samsung Frame, just because it is very flat and would save some studio space.
Béla Brandes | www.bbsounddesign.de
Old 11-09-2018, 10:47 AM
reichman's Avatar
reichman reichman is offline
Default Re: 3rd Monitor Choice / Audio for Picture
AJA T-Tap. Cheap, rock-solid and better video playback than the way you're doing it now.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-23-2018, 04:04 AM
Just found that the Aja T-Tap is not officially compatible with PT (https://www.aja.com/compatibility/io). But seems like Aja do support other interesting options for thunderbolt graphic devices. So thank you!
Old 11-29-2018, 01:29 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
You should not be using h264 as a codec for serious long form - inconsistent sync and variable play pass timing due to cpu processing between key frames.
Convert to DNxHD36 or ProRes
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 12-23-2018, 04:01 AM
Thank you for mentioning. Yes, i normally use MPEG Streamclip to transcode files to either ProRes or DNxHD
Old 12-27-2018, 11:27 AM
DonaldM's Avatar
DonaldM DonaldM is offline
What would you recommend for a Windows setup?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 12-27-2018, 11:42 AM
reichman's Avatar
All of those AJA products are Windows-compatible. I'm pretty sure all the Kona cards work on Windows. You could find a used on and save some money.
Nathaniel Reichman
Old 12-27-2018, 11:49 AM
DonaldM's Avatar
Thanks for the tip!
Old 12-27-2018, 05:10 PM
TheMuffinMan01 TheMuffinMan01 is offline
T-Tap works great in my up to date macOS/PT Ultimate system and has for the past couple of years fwiw.
Old 12-30-2018, 10:39 AM
Whats the main benefit for you running the signal through the Aja T-tap?
HTML code is On
who uses picture monitor for plugins etc? The Cargo Cult Post - Surround - Video 17 05-09-2013 04:36 PM
need a little help making monitor choice x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-11-2006 11:46 PM
Audio Workflow with picture changes?? dcaudio Post - Surround - Video 9 08-18-2004 06:54 PM
Playing to Picture on seperate monitor or TV Ronnisi Pro Tools TDM Systems (Mac) 15 09-02-2003 07:51 PM
active vs passive monitors? monitor choice? isolde 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2002 07:01 AM
