Video Satellite LE sync question
Just finished a 20 min documentary mix in PT HD ( on Windows XP ), video playback is via VS LE on a Macbook Pro ( outputting via Canopus ADVC-100 ). After i bounced my final mix and imported into Final Cut Pro i noticed that i needed to nudge forward 4 frames in order for the audio to be in sync. This nudge is the same amount used to sync offset on the VS-LE rig.
Is this normal ??? i don't remember having to do this when the video was played locally ( on PT machine ). Then, I still needed to sync offset 16 quater frames ( compensate for the Canopus ) ) but the bounce was perfectly in sync once imported to FCP. Is this a PT 8 or VS-LE issue ??? Thanks |
Re: Video Satellite LE sync question
Anyone ??
Video Satellite LE -> Sync HD required? | Meads | Post - Surround - Video | 12 | 05-30-2012 09:03 AM |
sync problems with Video Satellite LE | CD Productions | Post - Surround - Video | 5 | 05-16-2011 01:22 PM |
Video Satellite Ref/Sync issue | budster | Post - Surround - Video | 4 | 08-25-2010 02:05 PM |
sync video with pro tools using satellite le | ericlees | Post - Surround - Video | 6 | 03-13-2010 09:36 PM |
Video Satellite LE Sync Problems | jmattchan | Post - Surround - Video | 12 | 08-22-2009 09:45 AM |
