W7 Mbox 2 DIGI 003 + PRO TOOLS 10 = HELL ON EARTH
Hey first off if anyone important at avid is reading this I want you to know you have made my life a living hell. I used to have pro tools 8 with my windows xp 32 bit i7 build and it worked amazing! At 64 buffer i was running a million plugins!! And still recording at that! I moved of to windows 7 64bit and i want to kill myself. I've built two i7 rigs and both have yet to flawlessly work with protools 8 9 or 10. I started off with my mbox 2, you guys say it's "compatible" so I installed all the new drivers and a clean install of pro tools well, it freezes on start up, has trouble "locating hardware" and BSOD's my computer to sleep. So I threw my mbox2 piece of [bleep][bleep][bleep][bleep] out of my four story apartment building. then I try my 003 which I have plugged into my "compatible" pcie FireWire card that I bought so it could work properly. And the same thing happens freezes on startup. My buffer size can't go down to 64 anymore with getting hell of dae errors!!!! I just want to make music!!! can someone please just tell me what I should do?? I don't want to post a stupid Sandra report I've read EVERY thread in these forums!!! I have yet to see anyone's problems SOLVED!!!! So what's going on? Should I call avid tech support? Is there such thing? do I have to pay 30 dollars a hour so you guys can [bleep][bleep][bleep][bleep]ing help me fix YOUR PROGRAM? Should I have bought a HP or a DELL? That's "compatible"? What does "compatible" mean to AVID? Fml..... Someone please give me some answers!!!!!
Computer Model : GigaByte H67MA-USB3-B3 Workgroup : WORKGROUP Host Name : DiddyNac-PC User : Diddy Nac Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.69GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core L1D (1st Level) Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 (2nd Level) Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 (3rd Level) Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte H67MA-USB3-B3 BIOS : Award (OEM) F3 03/31/2011 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Video Adapter : ATI Radeon HD 4800 Series (Microsoft Corporation WDDM 1.1) (800 SM4.1, 512MB DDR3 256-bit, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) : 932GB (D:) WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (E:) OCZ-AGILITY3 (240GB, SATA600, SSD) : 224GB (C:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Disk (, DVD+-R, CD-R, 512kB Cache) : N/A (G:) Logical Storage Devices Audio (D:) : 932GB (NTFS) @ WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) Production (E:) : 298GB (NTFS) @ WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) System Reserved : 100MB (NTFS) Hard Disk (C:) : 223GB (NTFS) @ OCZ-AGILITY3 (240GB, SATA600, SSD) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ Disk (, DVD+-R, CD-R, 512kB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte H67 LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller Audio Device : ATI (AMD) HD48x0 audio Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte Etron USB 3.0 Extensible Host Controller FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Re: W7 Mbox 2 DIGI 003 + PRO TOOLS 10 = HELL ON EARTH
A Sandra report contains critically pertinent info on your system. Asking someone to tell you what you need to do without it is not very helpful.
You might try checking to see if you are using the legacy driver for your "compatible" pcie firewire card. Win 7 does not play with firewire as nicely as XP, the legacy driver helps greatly. I am running an 003r with PT 10 and Win 7 64bit with no problems at all, down to 64 on the buffer settings. BTW, I would have given you at least 20 bucks for the mbox 2 before you chucked it out the window.....
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek |
HAHA damnit i shouldnt have chucked it! I can try to put it back together for you! lol
Heres my SANDRA report SiSoftware Sandra Computer Model : GigaByte H67MA-USB3-B3 Workgroup : WORKGROUP Host Name : DiddyNac-PC User : Diddy Nac Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.79GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core L1D (1st Level) Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 (2nd Level) Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 (3rd Level) Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte H67MA-USB3-B3 BIOS : Award (OEM) F3 03/31/2011 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 7.92GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Shared Memory : 66MB Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Video Adapter : Intel(R) HD Graphics Family (6 SM4.1 850MHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Graphics Processor Compute Shader Processor : Intel(R) HD Graphics Family (6SP 850MHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Storage Devices WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) : 932GB (D:) WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (E:) OCZ-AGILITY3 (240GB, SATA600, SSD) : 224GB (C:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Disk (, DVD+-R, CD-R, 512kB Cache) : N/A (G:) Logical Storage Devices Audio (D:) : 932GB (NTFS) @ WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) Production (E:) : 298GB (NTFS) @ WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) System Reserved : 100MB (NTFS) Hard Disk (C:) : 223GB (NTFS) @ OCZ-AGILITY3 (240GB, SATA600, SSD) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ Disk (, DVD+-R, CD-R, 512kB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte H67 LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller (I Disable This Also)Serial Port(s) : 1 Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte Etron USB 3.0 Extensible Host Controller FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) (I Installed The Legacy Driver) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) (I usually have this disabled) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Don't mess around with legacy drivers... get a modern FW card with a TI chipset.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
OK SO I JUST PUT IN MY GRAPHICS CARD
Computer Model : GigaByte H67MA-USB3-B3 Workgroup : WORKGROUP Host Name : DiddyNac-PC User : Diddy Nac Processor Model : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed : 3.69GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core L1D (1st Level) Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 (2nd Level) Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 (3rd Level) Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte H67MA-USB3-B3 BIOS : Award (OEM) F3 03/31/2011 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Video Adapter : ATI Radeon HD 4800 Series (Microsoft Corporation WDDM 1.1) (800 SM4.1, 512MB DDR3 256-bit, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) : 932GB (D:) WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (E:) OCZ-AGILITY3 (240GB, SATA600, SSD) : 224GB (C:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Disk (, DVD+-R, CD-R, 512kB Cache) : N/A (G:) Logical Storage Devices Audio (D:) : 932GB (NTFS) @ WDC WD1001FAES-60W7A0 (1TB, SATA300, 3.5", 7200rpm) Production (E:) : 298GB (NTFS) @ WDC WD3200AAKS-75L9A0 (320.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) System Reserved : 100MB (NTFS) Hard Disk (C:) : 223GB (NTFS) @ OCZ-AGILITY3 (240GB, SATA600, SSD) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ Disk (, DVD+-R, CD-R, 512kB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte H67 LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller Audio Device : ATI (AMD) HD48x0 audio Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte Etron USB 3.0 Extensible Host Controller FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) (003 Not Recognized?) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Did it make a difference?
i dont think so my digi 003 isnt being recognized now?
Have you tried swapping FW cables? Have you tried plugging it into another system to make sure it isn't the 003 itself? Is your FW card a Texas Instruments chipset?
yea it is! i copy and pasted the serial number of the compatible firewire card from the avid website onto amazon and got it! at this point im just about ready to give up. should i purchase a new interface you think? my life was so much easier when my pro tools was running as it should im [bleep][bleep][bleep][bleep]ing stressed out right now
Did you check the Device Manager to make sure there is no issues after you installed the Graphics Card?
How on earth does one order upgrade from PRO TOOLS 10 + CPTK to PRO TOOLS HD 11 ?? | mbat4100 | Pro Tools 11 | 3 | 06-22-2013 08:49 PM |
W7 mbox 2 digi 003 = HELL ON EARTH | nicnac712 | Windows | 4 | 11-29-2011 04:39 PM |
Sidechaining in Pro Tools 10 - hell one earth | Stay Where I Can | macOS | 0 | 11-27-2011 01:00 PM |
Pro tools, digi 002, rewire and drum kit from hell | Acle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-15-2004 11:38 AM |
mbox hell...please help | ejsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2003 05:06 PM |
