Reason Dr. Rex issue
Fellow Users...Protool users that is,
I'm having an issue related with Reason's Dr. Rex. I'm running a G5 dual 2.5 with PT 6.4 and Reason 2.5 (rewire) with a 002r. I'm able to instanciate two Dr. Rex's but by the third one I'm not able to send MIDI data to track. I can't figure it out because i'm able to send data on the first two Rex players. This is the second time this happened on a separate session so I'm thinking it's a bug. I submitted a report to propellerheads regarding this and another known issue with distortion while audtioning rex files but oddly enough they had no answer for this one. Thanks, RS Quote:
Re: Reason Dr. Rex issue
You must have a selection (in Pro Tools or Reason) to use the To Track function in Dr Rex.
Rail
Thanks anyways, RS |
its a [bleep] bug with dr. rex/reason 2 & 2.5 i think 2 dr rex instances and the [trak to midi] is all you'll get, then nothing??? wtf!!
i spent way too many hour with that falker ; [ |
Finally, somebody found a bug in Reason 2.5?
Quad 2.5 G5, 4.5G RAM |
If it's a bug then a it's a weird one because I know of people that can bring up multiple Dr. Rex players with no problem on much slower processors. It's gotta be a compatiblity issue with the dual 2.5 (and PT6.4 w/ Reason 2.5 ?) unless others are experiencing this problem with other systems. Propellerheads has'nt acknowledged this one as a bug but the distortion when auditioning 24 bit REX files is a known bug in 2.5.
RS |
PT 8.0 + Reason issue + PT 8.0.1 update issue | caz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2011 02:01 PM |
PT 8 and Reason 3 Issue | VanDerGraf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-16-2009 03:06 PM |
PT 7.4 w/ Reason 4 Issue! | Say-Wut | Pro Tools M-Powered (Win) | 1 | 04-03-2008 04:15 PM |
Issue with Reason | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-28-2006 10:38 AM |
REASON Issue | mikeW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-28-2003 12:42 AM |
