Old 08-12-2007, 03:48 PM
98wildcat 98wildcat is offline
Default ICON D Control Sends and Pans
I tried using FLOP but couldn't get this:
I want to see SENDS A on the first row above faders, then PANS on the second row.
Is there a way to set this up?
When I moved my SENDS to the first row, I lost the Pans, it seems I can only have one row working at a time...
Thanks
scott
Old 08-12-2007, 10:13 PM
Mikey MTC Mikey MTC is offline
Default Re: ICON D Control Sends and Pans
Hmmm, I don't think you can actually do that. I think the only time you can have the pan pot and something else together (sends, inserts, etc) is when the pan is locked on the bottom pot via the pref. Anything else then has to be above that bottom panner.
Someone else please correct this if it's wrong.
Old 08-12-2007, 11:49 PM
Well, at least if I can keep the pan in the first row and put sends A-F in the second row that would be good...Its having them both up at the same time that is eluding me.
Thanks again
Old 08-13-2007, 05:02 AM
Doing it that way is easy - that's the way I do it most of the time.
(1) Set pref to have pan always on bottom fader. PanBot = On
(2) Set pref for encoder order to be bottom to top.
Old 08-13-2007, 07:03 PM
ok...
Me being a nubie..Sorry:
How do I do those things you suggested?
Thanks
ok...
Thanks
Old 08-14-2007, 01:29 AM
ok...
Thanks
You ARE a noob!! <g>
In the soft keys section press "Operation" in the "Console Prefs" section. Keep pressing it until you see the page that has "PanBot" on the top left. Set this to say "Yes." That's your pan knob locked to the bottom encoder.
Directly to the right of that one you will see "Encod" which you need to set to "Bot-Tp" which will start your sends and inserts from the bottom going up as you need.
Pans window on control|24 how see? tamtamstudio ICON & C|24 0 03-24-2012 05:59 AM
Icon Faders Stuck on Aux sends with Pro Tools 9 acacia ICON & C|24 2 11-29-2010 07:00 AM
ICON Cue sends budzter ICON & C|24 3 02-03-2005 11:45 PM
Send pans follow channel pans? woodshopsound Pro Tools TDM Systems (Mac) 2 10-14-2004 01:36 PM
MIDI control of pans on stereo channels Rusk MIDI 0 09-25-2002 05:33 PM
