Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 10-07-2018, 04:40 PM
MusicMadness MusicMadness is offline
Default Using Beat Detective to create a MIDI track
Hi guys, can I use transient markers from Beat Detective to create a new MIDI track basing on them? I found several topics from 10 years ago when people were requesting for this feature but I couldn't find any info about current state - have they implemented it already? Or maybe you have some easy way to work around this?
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 10-07-2018, 05:12 PM
amagras amagras is offline
Default Re: Using Beat Detective to create a MIDI track
What exactly do you want to do? Do you want to create MIDI from a drum multitrack or from a loop. I assume you are talking about rhythmic instruments because this wouldn't work with melodies.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-07-2018, 05:36 PM
I want to create midi track based on a drum track and then use it to trigger gate plugin.
Old 10-07-2018, 07:01 PM
Yes yes but... loop or multitrack?
If you want to trigger a gate why don't you simply use a pre fader send?
amagrasmusic.com
Old 10-07-2018, 07:23 PM
Multitrack
That's what I usually do and this time I wanted to try it another way. I have a lot of dynamic changes between different parts of song and instead of playing with gate settings I wanted to make additional track with very short and dynamically constant sample to trigger gate. That would be also useful for adding drum samples in future. If I need to go through all the track to correct timing why not to make midi from these transients anyway? I was expecting to see such an option in Groove Template Extraction -> Extract window but there's no way to save it as MIDI. Any Ideas?
Old 10-10-2018, 12:59 PM
beefpitas beefpitas is offline
Try the Steven Massey plugins drt or “dirt”
It creates a midi file you can use to trigger other sounds or samples.
It’s pretty intuitive and easy to use.
There was a free version with limited functionality and a paid version which does more.
Old 10-10-2018, 01:26 PM
Benoni's Avatar
Benoni Benoni is offline
Le Sound Groove Extractor might work
or download the trial of FL Studio, load your audio into Edison and dump to piano roll. Export MIDI and pull into Pro Tools. You can Rewire FL into Pro Tools too.
or tab to transients and do it manually.
Old 10-10-2018, 06:48 PM
Melodyne
amagrasmusic.com
Old 10-11-2018, 07:58 AM
nigelpry's Avatar
nigelpry nigelpry is offline
Drumagog
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.13.6 and Windows 10
Macbook Pro 2011 17", 2.2ghz i7, 16gb RAM OS 10.12.6
Digi 003 Console, Focusrite Octopre and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad with Thunderbolt card, Apollo Twin mk11 and pci-e Octo, Adam A77X monitors.
Pro Tools 2018, Media Composer 8.9, Sibelius 8.7, Cubase Pro 10, Wavelab Pro 9.5, Logic Pro X, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Beat detective from midi track - no click- help, please? jeremyroberts Pro Tools TDM Systems (Mac) 4 12-10-2010 08:39 AM
Best way to Beat Detective from a midi track? jeremyroberts Pro Tools 9 0 12-10-2010 06:43 AM
Beat Detective Midi Track Generation caustic Tips & Tricks 7 01-28-2008 09:00 AM
Beat Detective (MIDI) and Tempo Track GreyLion Pro Tools M-Powered (Win) 2 01-04-2006 08:02 PM
