Old 06-09-2011, 01:57 PM
animation_nerd animation_nerd is offline
Default BUG: PT-M 8.05 Crashes when Previewing effects as non-administrator
I submitted this bug months ago, along with a few others. I haven't seen the bugs fixed in 8.05 nor have I been contacted for more details, so I'm posting it here in
the hopes of getting some help. Perhaps in the way of a CS update, hack or a workaround?
This bug occurs when logged in as a non-administrator on Windows 7 64 bit.
This behavior was introduced around 8.03?? I'm pretty certain that this particular bug doesn't occur in 8.0
M-Audio Fast Track Pro, driver ver. Install: 6.0.7 - Driver: 5.10.0.5134
Steps to reproduce:
1. Log in as a non-administrator
2. Create new PT session.
3. Import an audio file into a new track.
4. Select a region.
5. Select AudioSuite->Pitch Shift->Pitch Shift
6. Press the Preview button.
7. Press the Preview button again to stop the preview.
8. Pro-Tools will crash/stop responding with one or more of the following messages
Runtime Error!
Program: C:\Prog...
R6025
-pure virtual function call
Access violation occurred, unable to read location: 0x6C6C642E at address: 0x10035613 in module: CFnd.dll
Access violation occurred, unable to read location: 0x00000004 at address: 0x073A5EB6 in module: ProTools.dll
(Note: This crash will occur with other AudioSuite previews too)
Because I support a full lab of Pro-Tools (26 stations) in a shared lab space at an educational institution, it is important that the users remain non-administrators.
This has been the only BUG of real importance that we've run into related specifically to non-administrator privileges.
Also note: I've tried many fresh installations on different machine configurations.
Please help!
Link to .dlog files: https://rapidshare.com/files/3296311...-admin_bug.zip
Computer
Model : HP HP Z600 Workstation
User : Administrator
Processor
Model : Intel(R) Xeon(R) CPU E5630 @ 2.53GHz
Speed : 2.66GHz
Cores per Processor : 4 Unit(s)
Type : Quad-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 12MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 32 threads sharing
Computer
Mainboard : HP 0B54h
BIOS : HP 786G4 v03.08 04/23/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 12GB ECC DIMM DDR3
Chipset
Model : HP 5520 (Tylersburg-36D) I/O Hub
Front Side Bus Speed : 2x 3GHz (5.85GHz)
Chipset
Model : HP Server (Gulftown) Uncore
Channels : 3
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT351U7AFR8C-H9 4GB ECC DIMM DDR3 PC3-10700E DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA Quadro FX 3800 (192 SM4.0 1.3GHz, 1GB DDR3 1.58GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : NVIDIA Quadro FX 3800 (192SP 24C 1.2GHz, 1GB DDR3 1.58GHz 256-bit)
Compute Shader Processor : NVIDIA Quadro FX 3800 (192SP 1.3GHz, 1GB DDR3 1.58GHz 256-bit)
CUDA Processor : NVIDIA Quadro FX 3800 (192SP 24C 1.2GHz, 1GB DDR3 1.58GHz 256-bit)
Storage Devices
Hitachi HDS721050CLA362 (500.1GB, SATA300, 3.5", 7200rpm, 14MB Cache) : 466GB (C:)
hp DVD A DH16AAL (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2kB (D:)
Logical Storage Devices
Hard Disk (C:) : 466GB (NTFS) @ Hitachi HDS721050CLA362 (500.1GB, SATA300, 3.5", 7200rpm, 14MB Cache)
Optical Drive (D:) : N/A @ hp DVD A DH16AAL (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : HP LPC Interface Controller
LPC Legacy Controller 1 : SMSC SCH5317-B
Audio Device : HP HD Audio Controller
Audio Codec : Realtek Semi 262 High Definition Audio
Disk Controller : HP ICH8R (ICH8) SATA RAID Controller
USB Controller 1 : HP USB UHCI Controller #4
USB Controller 2 : HP USB UHCI Controller #5
USB Controller 3 : HP USB UHCI Controller #6
USB Controller 4 : HP USB EHCI Controller #2
USB Controller 5 : HP USB UHCI Controller #1
USB Controller 6 : HP USB UHCI Controller #2
USB Controller 7 : HP USB UHCI Controller #3
USB Controller 8 : HP USB EHCI Controller #1
FireWire/1394 Controller 1 : HP FW322/323 IEEE1394 OHCI FireWire Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Peripherals
Network Services
Network Adapter : Broadcom NetXtreme Gigabit Ethernet (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Performance Enhancing Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 06-23-2011, 12:23 PM
Default Re: BUG: PT-M 8.05 Crashes when Previewing effects as non-administrator
Any advice on solving this problem??
This is from the Windows Event Viewer:
Problem signature:
Problem Event Name: APPCRASH
Application Name: ProTools M-Powered.exe
Application Version: 8.0.5.60
Application Timestamp: 4d6f7153
Fault Module Name: CFnd.dll
Fault Module Version: 8.0.5.60
Fault Module Timestamp: 4d6f5d27
Exception Code: 40000015
Exception Offset: 0003563a
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 4105
Additional Information 1: 0273
Additional Information 2: 027333e70af5c707ec71dc376ff3e0b6
Additional Information 3: 00f4
Additional Information 4: 00f41fb4ce75e1ce26c10ef87e219543
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Old 06-23-2011, 12:34 PM
scenicrecords scenicrecords is offline
Not really a bug - Avid recommends running Pro Tools as an administrator.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 06-26-2011, 03:30 PM
Wavelabs Wavelabs is offline
I ran into this same problem using PT 8.0.5, when i upgraded PT.
But I was doing Normalization/Gain Change
And When I pressed Preview..... Booom CRASH..
Happens all the time.
So I down-graded back to v8.0.4 and it stopped the crashing.
But of course, I was back to the previous problems I had, which was why I did the upgrade to v8.0.5
Staff in music stores are starting to name PT "The glitchy software"
Every time I go into a music store and ask staff questions.
AMD Phenom II X4 940 w/ CoolerMaster V8 Cooler - GigaByte GA-MA790FXT-UD5P - ATI Radeon 6850x2 (x2) - Win7 x64-bit - AMS Venus-T5 with 1-TB x5 Drives
Kingston Hyper-X DDR3-1066 2gig x4 (8gig Ram) - WD SATA VelociRaptor 300 (x4) - XXXXXXXXXXXXXXXXXXXX - Groove Tubes GT-66 & 55 Microphones - BBE 422-A - Aphex 104 C2
Vantec MRK250ST w/ Win7 x64-bit (HotSwaped for ProTools v8.0.4 Unit) - Acer v223w (x2) LCD Screens - Events 20/20 - Avantones - Mackie HR824 - AKG P220 - HS50m's
Old 07-04-2011, 07:16 AM
This problem has been happening to us since moving to Windows 7 and upgrading past 8.0.
There have been numerous important changes since 8.0. Windows 7 and non-administrator users are musts in our shared-space labs.
Old 07-04-2011, 10:48 AM
Avid has published this guide, "Pro Tools Windows NonAdmin Guide", which was geared toward XP:
http://akmedia.digidesign.com/suppor...uide_56150.pdf
So, Avid doesn't seem entirely opposed to non-administrators. To my knowledge they haven't published one for Win 7.
I understand that recommendation for a home or studio user. But in an educational environment, administrator privileges is a non-starter. As I mentioned above, the crash did not occur in 8.0, it drifted in with the .0x updates, so it was working at some point.
Old 07-05-2011, 09:58 AM
I see - you're in a lab environment. All I can find is that here it says "Run as Administrator" is a "Required Optimization" for Windows 7. Maybe try this configuration which will always run the Application as an Administrator for any user.
Windows 7 64-bit
Old 07-06-2011, 09:02 AM
Unfortunately, UAC still prompts for an admin username and password when you try to elevate privileges (which is a good thing). I think the ProTools team simply has to work on a fix or suggest a feasible workaround for an educational lab environment. Run as Admin and disabling UAC are a bit more than an "optimization".... You shouldn't have to undermine the security of your computer to run a single application. No other piece of software we use has this problem.
Crashes with user, but not with administrator N8ty macOS 1 02-08-2011 11:17 AM
Pt8 crashes previewing audio in workspace fridrikur Pro Tools M-Powered (Win) 6 02-21-2009 04:56 AM
No audiosuite previewing on 6.8 MP help ! frenchman Pro Tools M-Powered (Win) 1 01-17-2006 12:19 AM
Previewing in the "Import Track" window crashes PT chicoman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2005 06:48 PM
Absynth Previewing Logan M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-20-2002 04:39 AM
