Old 07-14-2005, 08:25 AM
Eric G Eric G is offline
Default Suggestions for Room Treatment?
I am working in a small temporary office (about a year). I am looking for room treatment sollutions that aren't permanent. I will primarily be recording interviews and V.O. I need something to help isolate the two people when recording an interview. Links? Articles? Help appreciated. Eric
Old 07-14-2005, 09:09 AM
C52382P C52382P is offline
Default Re: Suggestions for Room Treatment?
On a budget : A frame of some sort (ie wood, mic stands, anythying you can drape something over) and standard A/C Duct Work insulation can be used to make portable gobos. These work better than you might think. For trapping the bass that builds up in corners try 1 inch wooden dowels or broom sticks or anything like that wrapped in either duct work insulation or carpet pad until you have a thick pole. Just lean them in the corners and they will help alot with bass problems .
Old 07-14-2005, 10:44 PM
Tubedriver Tubedriver is offline
http://www.modularacoustics.com/
speak to Nick
Tube
iMac G4 20" flat panel 512mb OSX 10.3.7
Lacie 160gb D2 Triple Extreme
Digi002R - PTLE 6.4
Old 07-17-2005, 09:53 PM
msunj msunj is offline
check out this link
http://www.geocities.com/jonrisch/index2.htm he gives good instructions for building wall panels etc that have helped my room quite a bit.
Old 07-18-2005, 07:51 AM
EF EF is offline
Check out Maxxwall products from Auralex www.auralex.com or Primacoustic www.primacoustic.com makes a similar product. You can make your own, but if you need something that doesn't look more professional check out above products. They are also lite weight and break down to store in a relatively small area.
G5 1.8DP 4 gig ram, 002
Waves Platinum, UAD-1 Studio Pak, Reason 2.5, BFD
Presonus Digimax 96K, UA 6176, Mackie Onyx 1640
Room Treatment...need help! AM STUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-12-2005 12:46 PM
Room Treatment with Bookshelves GuitarEasley General Discussion 5 07-18-2003 04:57 PM
Acoustics - Room Treatment Brian Maxwell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2003 12:51 AM
HELP!!!!!! Room Treatment vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 01-12-2003 07:28 PM
OT: ISO ROOM Treatment Tips tworooms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2002 11:25 AM
