Old 04-17-2018, 02:58 PM
dg27's Avatar
dg27 dg27 is offline
Default midi merge timing question
I wondered for a while how to merge MIDI notes so that they retain the original timing, such as slightly after the beat.
I have googled this a lot, but probably haven't posed the query correctly.
On the attached I want the notes on the right (circled in red) to match the timing of the notes on the left (boxed in green).
Is this possible? What setting do I have to change or tool must I use?
Old 04-17-2018, 10:59 PM
Stig Eliassen's Avatar
Default Re: midi merge timing question
You can extract the timing from notes with Beat Detective, save it to the clipboard or to disk, then quantize other notes with the extracted template.
Or, use relative grid mode, and Alt+drag the notes over to copy them.
EDIT: I mention relative grid mode since it looks like you're after an exact copy.
Old 04-18-2018, 05:48 AM
dg27's Avatar
Thanks, Stig. This seems to be the best bet because yes, I want an exact copy. It's an offbeat drum fill that I want use in other sections of the same song.
Thanks again!
Old 04-18-2018, 06:26 AM
ibbod0 ibbod0 is offline
if you want to copy and then merge paste, i find the easiest way is to just add an extra note that is on the grid and copy that along with your selection just so you can line it up again, and then delete the extra note. if that makes sense. but yeah, relative grid is great if it's not too far to drag.
Old 04-18-2018, 01:03 PM
dg27's Avatar
Thanks--I'll try that as well!
Old 04-19-2018, 02:25 PM
dg27's Avatar
This worked like a charm! Thanks.
Midi Notes already recorded drop when midi merge recording EdwardG Pro Tools 12 5 07-03-2019 12:44 AM
Midi Merge jino_f_a Pro Tools M-Powered (Mac) 4 06-19-2009 03:19 PM
MIDI Merge Denkelag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-17-2007 03:44 AM
MIDI v USB a question of timing RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-15-2005 04:42 AM
MIDI Merge Greg B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-29-2005 12:09 AM
