Re: Nomenclature
Re: Nomenclature
Thanks CME for the explanation.
I guess my last question was a little more elementary and just practical. Basically I was wondering whether you would load the 32-bit AAX plugin or the 64-bit AAX plugin on the S3L. Before there was just TDM that was loaded onto the live console, not 32-bit TDM or 64-bit TDM versions out. I understand that the software for ProTools can be 64-bit and thus use more of the available RAM, but I wasn't sure if the Venue Software for S3L would require the use of 64-bit plugins because the Venue Software is built as a 64-bit application (not sure if it is or isn't) or if it the Venue software is just a portal to manipulate what is going in the DSP and communicate to the other peripherals. The plugins may not be dependent on how the Venue Software was built. Brian |
Re: Nomenclature
Well for that question you'll have to get an answer from someone else. I'm really not familiar with the s3l and whether it uses 32 or 64 bit plugs.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
