Old 02-15-2014, 09:54 PM
TimNielsen TimNielsen is offline
Default EuCon Commands missing from Editor!
This has happened to me before, but usually closing EuCon and re-opening it fixes it, but in PT11 this has become almost unusable.
When trying to modify my surface touchscreen, I want to add a EuCon control to a touchscreen switch. Most of the time now, I cannot select any EuCon commands. When I add a EuCon command, all the windows that SHOULD show me all the various selections I can choose, are all blank:
https://dl.dropboxusercontent.com/u/...43.05%20PM.png
This is driving me CRAZY. Just to assign ONE button might take 20 'attempts' before I can get the menus to show up. But every once in a while they do, so I know they are there.
Anyone have any ideas? Does this make sense, has anyone else seen this? Trying to assign a EuCon command to the touchscreen shows blank menus where the choices should be?
Old 10-14-2014, 09:50 PM
Macsearcher Macsearcher is offline
Default Re: EuCon Commands missing from Editor!
Hey Tim.
Did you ever resolve the issue? I have the same problem exactly.
Old 02-23-2015, 03:52 PM
quantize quantize is offline
Same here, with latest Eucon 3.2.1 in OSX Mavericks 10.9.5
I have to 'Restart Eucon Application'
Flakey at best...a bit rich given the cost of these things.
quantize
Pro Tools 10.3.9 / Cubase 8 / Reason 8 / OSX 10.9.5
Mac Pro 2 x 2.8 gHz Quad Core Intel Xeon / 14GB Ram
UAD Apollo Quad / MOTU 828 mk3
Avid Artist Control / Blackmagic Design Intensity Pro
Old 02-25-2015, 12:29 PM
donnydonny's Avatar
donnydonny donnydonny is offline
Does the issue occur in other apps? What about other versions of Pro Tools?
Donny
Avid Community Team
Old 10-13-2015, 12:20 PM
Interactivesound Interactivesound is offline
I'm having this issue with the S3, Eucon 3.31, PT 12.2.1, OSX 10.9.5
Restarting Eucon applications generally fixes this, but you cannot switch to another application after Eucon launches. If you switch to anything aside from ProTools and Eucontrol will blank out the Eucon Commands.
Old 02-10-2016, 09:20 AM
bassmagnetic bassmagnetic is offline
I've been having the same problem for a couple of years... seems its to do with EuControl software not hardware specific as been the same with the Artist Series and now S3...
sort it out avid, simple bugs like this shouldn't be around for years!
Old 02-16-2016, 01:26 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Hey guys
Check to make sure that EuControl is actually looking at the Pro Tools XML. Often what happens is that you tab away from Pro Tools to check an Email or write a note on the softkeys you are creating, then tab directly back to EuControl. EuControl will always look at the XML for the last focused App. Easiest way to tell is to look at the "Application" setting in the upper left hand section of the Soft Keys tab. The only caveat is if you have the "Entire Surface" locked to PT in the Layouts page... Application will ALWAYS display Pro Tools.
Anyhow... easiest way to get your Eucon commands back is to focus on Pro Tools, then back to EuControl and you should have everything back. FWIW, this happens to me all the time as well.
I'm covering this and other Soft Key topics tomorrow in my Soft Key Tech Talk. If you have the time, please join us. Register below for the Webinar.
http://connect.avid.com/Tech-Talk-Q1...-Register.html
Mark
Mark Corbin
Eucon Surface & Pro Tools Product Champion
Audio Services Supervisor
For immediate assistance:
S6 Support - 888-456-3444
Venue Support - 650-237-1711
Euphonix Support - 650-237-1604
Pro Tools Support - 650-237-1700
Old 02-17-2016, 07:33 AM
Thanks for the message Mark. However my "Entire Surface" and "Transport" are always locked to Protools (checkbox ticked), so the commands not showing in Eucontrol isn't due to it being focused on another application.
Old 10-27-2016, 07:36 AM
simonchase simonchase is online now
I'm getting this too. It has worked once in ten tries
PT Ultimate 2020.11 - MacOS 10.15.6 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet
Can I use a maco with 2 eucon commands? Brandonx1 Artist Series 3 04-07-2012 08:54 PM
Eucon commands not stackable? robertg Artist Series 5 12-15-2011 11:15 AM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 03:35 AM
Pro Tools 8: Score Editor is Missing Noteheads TonyPT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-14-2011 12:46 PM
Filter Freak Missing Key Commands??? GKB Pro Tools TDM Systems (Mac) 2 12-18-2003 02:14 PM
