Re: PT & Orion 32 - playback issues at low buffer settings
Yes!
This makes sense, and thank you for the insight TNM. I was skeptical of the conclusion Antelope support came to from the Reaper test. I've been running the Orion for about a week and have successfully tracked through it for several sessions. I find using the Orion with the buffer set to 256 and the USB setting at MIN LATENCY seems to be the equivalent of tracking through the 002R with the buffer at 64. I'll have to run some tests to measure the actual latency. So it's working, but I would still like to be able to utilize the lower buffer settings and super low latency that Antelope boasts. I do have PT11 but have been running on 10 with good stability (also some Massey plugins won't work on 11) so haven't been running 11, it's worth a test though. I'll install and try 11 on my secondary system with the Orion and we'll see how that goes. Another thing I noticed today is that when I open a PT session of a sample rate different than the last one I was working with, I have to restart PT and set the Orion clock again. Example: Mix session at 48k. Finished. Close PT, set Orion clock to 44.1k, open 44.1 session, clock error message. Close PT, set clock again, reopen session, works. So it seems to want to only work at the sample rate of the last session that was running. Requires an extra PT restart every time to change clock effectively. |
Antelope Orion and Dangerous Source issues. | joeboisits | Pro Tools 10 | 3 | 05-26-2015 02:34 PM |
What's the lowest playback engine buffer settings you are having success with? | songwritersoul | Pro Tools HDX & HD Native Systems (Win) | 3 | 07-19-2014 10:31 AM |
H/W Buffer Size issues (-6093), have tried many settings, no solution! | codydboyce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-06-2011 01:20 PM |
advice on playback and buffer settings | ggmmss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-06-2005 05:15 PM |
