Old 07-22-2017, 08:37 AM
J-S-Q J-S-Q is offline
Default Cubase/Nuendo Issue: Incorrect fader values
With Cubase and Nuendo, there has been a long term issue with Eucon controllers giving incorrect fader values:
After the faders reposition when banking to a new set of channels, if you touch a fader, it will often register a slightly inaccurate value. e.g. the channel may be at a level of +1dB in Cubase but when you first touch the fader on the S3, it will register a slightly different value of let's say 1.05dB, causing the Cubase channel to change volume very slightly. Of course when this happens tens or hundreds of times during the course of working on a session, it messes with your mix balance.
I've never seen this happen in Pro Tools.
Is there any chance of it being fixed?
Anyone using S6 with Cubase and/or Nuendo ? vudoo Avid S4/S6 4 09-22-2015 10:26 AM
Control 24 self test, no fader values touch mode Analogue_Rocks ProControl, Control|24, Command|8 0 06-13-2015 01:47 AM
Fader Display Values TAFF ICON & C|24 3 05-21-2009 03:09 PM
fader and values Paolo Costola ICON & C|24 0 09-30-2004 07:39 AM
cubase or nuendo to pt billy the kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-19-2003 02:43 PM
