Old 09-08-2017, 03:37 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Default Re: AIR Upgrade Offer?
Originally Posted by unkJE View Post
Get your Redemption Code here:
http://www.airmusictech.com/PROMOCODES
Enter the email address with which you registered your original purchase, copy the Confirmation Code then paste it in the next space, then click Submit.[/I]
Hope this helps!
Thanks for your your help unkJE.
Now, I've sent them several e-mails. They don't get back ...
Been using Strike since the beginning.
Upgraded everything to v2 (iLok) a few moths back, and thought I'd upgrade to the latest now.
I guess I'll skip that for now ...
Cheers.
Old 09-08-2017, 11:07 AM
Gemylon's Avatar
Got response from inMusic right now.
Maybe they're not so bad after all ...
Cheers
Old 09-09-2017, 01:28 AM
pianosound pianosound is offline
I had got this 2 years ago, same price seems to be the same thing? Structure , Strike etc. are still 2.0.7, not 3.0??? (As mentioned earlier here). So is there anything here that has been upgraded, or is it what I got in 2015?
Also, been using Strike more lately, not able to change to a different drum or cymbal in a kit. In checking the folders (Kits, Styles, Mixes, Settings, etc.) they are all empty?? Should these have the instruments I need, or are the 'Big files' all I need??
Any help here appreciated! Thanks ,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Old 09-09-2017, 05:22 AM
unkJE's Avatar
unkJE unkJE is offline
Strike is the same as what you got in 2015.
.... not able to change to a different drum or cymbal in a kit.
See attached images – drag & drop a kit component from the Browser or import your own kit component sample.
Copy your Presets Folder from:
C:\Program Files (x86)\AIR Music Technology\Strike
Paste it in:
C:\Users\User Name\Documents\Pro Tools\Plug-In Settings
then change its name from Presets to Strike
Restart computer
Then, on your Samples drive, within the Folder called Strike -
(Samples:\AIR Music Technology\AIR Content\Strike)
you should see all 15 Strike BIG Files, as well as 5 Folders:
Kits, Mixes, Recorded Audio, Settings, Styles
These 5 Folders should now contain all your User Presets (automatically sorted where you saved them)
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 09-09-2017, 08:03 PM
Thank you so much unkJE, All I have in the Strike folder, (program86\airmusic\) is the user guide, v1.2. I think with 3 or 4 upgrades through the years, I've got a mess! I had three different air music tech folders on my (F) drive, deleted two of the older ones without the 'big' files. And so now I have the 5 folders (empty), the 15 big files, a Strike, Strike 2.0.7 setup, and Strike factory content files...?? Although I think this folder is correct, I'm still missing something!?? Can I ,, (should I),, reinstall, leaving the big files in place, or maybe delete and uninstall everything Strike, and start from scratch?? Thanks again,, would really love to get this working correctly, been needing it a lot more lately. Mike
Old 09-09-2017, 08:20 PM
OK,, so the drag and drop (individual drum) works fine, THANKS! Still not sure what to do about the 5 empty folders? Is there somewhere else I might find that 'presets' folder?
Old 09-09-2017, 08:26 PM
I also have looked in the,,, C:\Users\User Name\Documents\Pro Tools\Plug-In Settings,,, just to check, and there are no files named presets, or Strike.
Old 09-09-2017, 08:30 PM
And so here's a real (probably) dumb question,,, but would these files be empty because I've not saved anything in the way of Strike kit changes yet, (or styles, mixes etc.) Or are there files that come with Strike that should already be there?? Actually, since clicking on the little folders across the top of the kit gui in strike still comes up with nada,,, I'm guessing that was a dumb question!
Old 09-09-2017, 11:20 PM
unkJE's Avatar
Hi Mike!
... there are no files named presets
.... would these files be empty because I've not saved anything in the way of Strike kit changes yet, (or styles, mixes etc.)
Sorry for not being more precise!
You nailed it - these are not Factory Presets - they are all User Presets - hence your empty Folders at this stage.
If your Manual has a pic on the front cover with the RECORD EXPORT box (AUDIO/MIDI) in the bottom RH corner, that's the Strike 2 Manual.
If not, you can download it here (RHS column in the middle):
http://www.airmusictech.com/product/strike-2#updates
Good to see you can drag and drop replacement kit components - the Import Samples function is a definite bonus, too.
Good luck and happy Strike!
Old 09-10-2017, 12:14 AM
Thanks, so the small folders across the top of the kit gui are only to use for changes made in the past and saved to the 'kit' folder? It would be nice if say in one of the tom tracks, I could try 8 or 10 toms to use in that track. Or snares in track #2 etc. And thanks for the manual! Much appreciated. Mike
$99 Upgrade Offer TimNielsen Pro Tools 9 4 12-12-2010 02:25 PM
Is this upgrade offer for real? mattrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-12-2009 11:07 AM
Why not offer a streamline PT8 upgrade? aliensurfmusic Pro Tools M-Powered (Win) 7 03-31-2009 02:21 AM
Best Plugs from the Upgrade PLUS offer ? Bossi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-14-2005 12:54 PM
? about PT HD upgrade/exchange offer ProdInfo Pro Tools TDM Systems (Win) 4 03-06-2002 02:31 PM
