Mark in/out points on S3
There doesn't seem to be anything in the Eucon command list for setting mark in/out points.
Within Protools, while playing, you can set mark in and mark out points by pressing the down and up arrows on the keyboard. I find this to be pretty essential to mix with the video monitor off. Is there any way of assigning this to the S3? I can assign keyboard clicks to the S3 but this won't help in this case. I want to be able to set mark in and out while ProTools screen isn't necessarily in focus. Thanks. |
Re: Mark in/out points on S3
You simply select a button and then assign up arrow using Eucon. Same goes for down arrow.
Many times I am comparing tracks to iTunes or some other application and only Eucon actions are program independent. |
Assign the command, but instead of choosing EuCon, choose Wheel, Dock Jog, Function and you'll see it. I don't have an S3 in front of me at the moment, but it should work.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
That did it. I'm fairly happy right now. :)
Thanks Reichman. |
Mark in - mark out, select area | ha2dorff | Pro Tools 11 | 10 | 02-11-2018 10:47 AM |
Mark out | druth77 | ICON & C|24 | 6 | 04-03-2011 06:21 PM |
Rec In/Out points independent from play/loop points like DP has? | spiritG | Pro Tools TDM Systems (Mac) | 0 | 10-01-2009 04:40 PM |
Mark | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-16-2002 07:33 AM |
how to use mark edit start mark edit end keys | c-post | Tips & Tricks | 1 | 02-07-2002 09:35 PM |
