MacPro 5,1 sweet spot?
Looking to buy a macpro 5,1 off ebay. Any models I should avoid? Budget is about 6-700 dollars. Should i buy a low spec machine and upgrade later? buy a 4,1 and firmware is to 5,1? Still hanging on with my 002r and i'm tired of mac book pro's logic boards s hitting out (2010).
2011 Macbook Pro ML 10.8.5 2.5ghz i7 16 gigs 256 gig SSD Pro Tools 10.3.10 and 12.3.1, 002r, Command 8 |
Re: MacPro 5,1 sweet spot?
I'm here to help if you want for the CPU upgrade.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
2011 Macbook Pro ML 10.8.5 2.5ghz i7 16 gigs 256 gig SSD Pro Tools 10.3.10 and 12.3.1, 002r, Command 8 Last edited by Audiosweeet; 05-27-2017 at 12:38 PM. |
I just updated my early 2009 4.1 MACPRO to a 5.1. I had bought it new when they came out.Make sure it is an 2009 if you do decide. Firmware upgrade is very easy to do. I just loaded in Sierra and everything runs sweet
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
Just want to make sure you know that you can also upgrade the CPU's on your computer to a 12 core.
The sweet spot is the 3.33 Hex CPU pairs. The very best is the 3.46 Hex pairs.
Get a 4,1 dual 2.26 and the 3.33 hexes. Get 24GB of 1333 ECC RAM, too. I delidded my CPUs so they were just like the Apple versions. Only took a few minutes and was safe. I can walk you through it using a vice, a rag, and a piece of tape. ;-) Tools: You'll need a long Allen wrench tool for the CPU coolers, some Arctic Silver thermal paste, some fine sandpaper (if you delid, which you should), a box of razor blades (if you're delidding), isopropyl alcohol, q-tips, paper towels, and about two hours, if you haven't done it before. You have to flash the firmware while the old CPUs are still in there. There's a trick to that if you get the error. It's easy. You also have to do the PRAM reset to get the higher RAM speed detected. I just did both my Mac Pros within the last 30 days, so this is fresh on my mind. If you're scared of all that, I'm for hire. ;-) If you're not scared of it and have at least a bit of handiness and tech savvy you will be done in 3 hours top to bottom. |
I sure do ! That if I decide to do will be done by someone who knows what they are doing. There ar a couple of youtube videos to show you how to do it. At this time I have enough power to do the things in my studio. Also great to have Sierra installed and I can keep up for a few more years if this thing lasts
Really, I thought it was tricky or if you messed up you could have problems. Maybe I will investigate further. I have a youtube video of it.
Using carbon copy to move from macpro to a newer Macpro | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 04-10-2012 02:39 PM |
A smaller, more focused sweet spot. | mikevarela | Post - Surround - Video | 1 | 03-27-2012 09:16 PM |
Spot function will not Spot?? | frequencypoet | Pro Tools TDM Systems (Mac) | 4 | 02-08-2010 11:29 AM |
PC and analog console - how do you share the sweet spot? | Inaam | ProControl, Control|24, Command|8 | 1 | 01-24-2003 03:43 PM |
AD8K input levels: "sweet spot"? | EJolson | Tips & Tricks | 0 | 12-19-2001 11:38 PM |
