Mbox Mini won't recognize Protools LE
Frustrated
System: Macbook Pro OS X 2.4 GHz Intel Core 2 Duo 4GB 1067 MHz DDR3 I have an Mbox Mini that I have been running Pro Tools LE 8.05 on for a while. I recently purchased a Maschine and was also using the Mbox Mini as its interface. Things were working fine for a couple of weeks. All of a sudden when I tried to open up Pro Tools I got an error message that says... Unable to locate Digidesign Hardware. Make sure your hardware is connected and turned on. Click ok when your hardware is ready. Things I have tried: * Checked to make sure cables are connected and working properly. * Installed current upgrades PT 8 LE 8.05 * Installed current Mac updates * Uninstalled and Reinstalled PT 8 LE Software If anyone knows how I can correct this problem, Please Help!!! |
Re: Mbox Mini won't recognize Protools LE
Does the light come on to confirm its connection? what version of the operating system are you using? Might need to install the driver from here... http://avid.force.com/pkb/articles/e...nload/en379411 Chris
Yes, the light on the Mbox comes on when I connect the usb to my mac. But, when I try to open Pro Tools is when I get the error messages. I will try to install drivers again.
I am facing a similar problem. I have an mbox 2 mini and have been using it with pro tools le8 on my macbook. Recently purchased a macmini and installed the same software and when i plug the mbox usb in the computer does not acknowledge it. The light will not turn on. Any suggestions?
What operating software? LE8 won't work with the very latest 10.8.x and doubt it will work with 10.7.x either. you will need to update to the latest version of PT To just use the Mbox you can install the latest drivers for your OS http://avid.force.com/pkb/articles/e...nload/en379411 Chris
Mac OS X 10.8.5 unable to recognize Mbox Mini | Steve Stokes | FireWire & USB Audio Interfaces (Mac) | 3 | 01-10-2014 10:53 AM |
Midi Won't recognize Mbox Mini | tjeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-23-2013 01:24 PM |
ProTools Does Not Recognize Mbox mini | RedIbis | Windows | 4 | 02-18-2012 08:24 AM |
sonar 8 CAN NOT recognize my MBOX mini | 32768 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-21-2010 07:51 AM |
PT 7.3.1 doesn't recognize Mbox Mini in Mac OS 10.4.10 | irongiant14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-08-2008 12:36 PM |
