Would this work? Two Operating Systems, One MacBook Pro?
The situation
I have a MacBook Pro mid 2009 (5,5) Core 2 Duo, 2.53GHz, 4RAM, 5400rpm HDD and I bought the upgrade to PT11 from PT8LE. I own the 003 mixer console, FireWire. I know that 8LE works well with Snow Leopard. PT11 works in some machines with Yosemite Complication My current laptop + Yosemite + 003 + PT11 doesn't seem to work. Questions Has anyone here done this, or would anyone have fact-based opinions about having two partitions on a hard drive and install: 1) Partition I: Snow Leopard with PT10, also a 32-bit app 2) Partition II: Yosemite with PT11 solely for mixing purposes Or should I just forget about PT11 and roll everything back to Snow Leopard and install PT10? Other than an optimized performance (ironic I'm saying this now), is there a significant difference between PT10 and PT11? Are the interfaces the same? I can only identify the new click track and the performance enhancements to be the difference between 10 and 11.
15" MacBook Pro 9,1 mid-2012 15in 2.6HGz i7, 16GB RAM, OS 10.12.1 | OWC 320GB FW400 7200rpm Digi 003 | PT 12.4 |
Re: Would this work? Two Operating Systems, One MacBook Pro?
How large is your drive? I had a 500GB on my MBPro and divided it into 3-partitions, which you can do at anytime. I had Mavericks, then installed Yosemite on a 2nd partition, and the 3rd was for DATA, i.e. non-system files and non-apps. You should easily be able to install your system and all necessary apps on 120GB or less.
With the above example, you would shrink your current partition to whatever makes sense, assuming you've got everything on a single one, then create a 2nd one of 100GB or so for Snow Kitty, or however you want to do it.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
I use a 500gb Lacie Rugged 7200rpm Firewire drive to record onto. My 003 console is connected using a SonnetTech Firewire Expressport Card. All working well, within the limits of the Core2Duo's capability and the outstanding issues with PT11. PT11 is more efficient than PT10 resource wise, which is good for older computers, but the issues are still a problem. Generally not bad on audio only projects, but I wouldn't trust it on projects with much in the way of VI. Better to use Vienna as a host in that case, that seems more stable than VI directly in PT11.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
DAWs as operating systems | peppertree | Pro Tools TDM Systems (Mac) | 6 | 03-08-2009 01:20 AM |
Dual operating systems??? | kaotikmuzik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-31-2004 04:20 PM |
How to run dual Operating systems? | Allan Speers | Pro Tools TDM Systems (Mac) | 8 | 11-22-2003 02:58 PM |
Bomb Factory and operating systems | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-15-2002 01:43 PM |
Operating Systems | mwollin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-28-2002 12:29 AM |
