Protools runs so slow on my computer! Please help.
First off, thanks to anyone that replies. I am running Protools 7.0 with my MBox with Windows XP. I already optimized my computer for audio, except I couldn't figure out how to de-activate hyper-threading. I so often get error messages when running Protools like, "Windows virtual memory is too low, your system is low on virtual memory, windows is increasing the size of your virtual memory paging file. And "Audio is conflicting with other CPU tasks. IF this occurs often, try reducing the buffer size in the playback engine. Then 5 minutes later it tells me DAW can't keep up and that I should increase the buffer size. Basically my computer has always had a hard time running protools. I have a HP Pavillion A810N with 160 gig, 512 MB of ram, the processor speed is 2.4 GHz. It seems like my computer should run a lot better than it is. It's pretty much to the point where I can't even record. I disable the internet, Norton AntiVirus, and Spysweeper when I run it. Can anyone tell me how to solve this problem? I was thinking of taking it in to the comp store and adding more RAM. Any help and insight is greatly appreciated.
Re: Protools runs so slow on my computer! Please h
Please start with the steps in The General Troubleshooting thread
Re: Protools runs so slow on my computer! Please help.
Do you have a dedicated audio drive, or are you trying to record to the system drive? You need 2 drives...one system drive, and one audio. That's one thing that might be causing problems.
I think you should upgrade your ram, Protools alone needs 512ram, you only have 512 running the whole system..so you need to upgrade your ram to 1GB....
Kryst |
Jimmy Jam |
When you purchase Mbox there is a manual, that shows you how to dis able hyper threading. I think the other way is to have your pc restarted, when it booting up hold the F1 key, then it should bring you to the dos menu, there you may disable hyper threading.
I got an Mbox 2 with PTLE 7.1 Computer Dell Dimension 3100 3.2 GHZ processing Prower Windows XP service Pack 2 1 GB Ram (512 x 2) Hard Disc Internal 80GB, partitioned into 2 drives, my OS runs on one partition and My Protools sessions alone runs in the Second partition. the only program that is running on my dell is "PROTOOLS" and nothing else....it works perfectly fine, and every time after a production session, you may need to do disc defragment, you need to do this very often, if not done, it will also slow down your PC. |
Well guys I added a full Gig of memory to my HP and things are definitely runner smoother. I will talke your advice and drefrag my harddrives often. Anything else that anyone can think of to assure I can run multiple plugins? What are the better reverb, delay, exciter, and compression plugins? I listen to some songs on the radio and it has a certain effect that I am not able to figure out.. Crossfade for example has it, it sounds very thick. I love it and want to find it. Can anyone help? Thanks everyone. |
help my midi and time in the session runs slow. | SteveR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-22-2008 01:58 PM |
Protools HD7 and Magma 13Slot PCI runs on MacPro? | pablotec | Pro Tools TDM Systems (Mac) | 0 | 10-25-2006 06:56 AM |
Long line runs between 002R and computer? | John J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-17-2005 08:49 AM |
Protools runs CPU at 100% then restarts computer | Stu Windle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2004 10:16 AM |
Burning CD's on the same PC that runs ProTools LE | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-07-2002 03:17 PM |
