The description for Event ID 0 from source digiSPTIService cannot be found
i first posted this in another thread, but it's getting buried, and i would like digi/avid to comment on it if possible. i realize i'm running win7 64-bit right now, which is dually unsupported, but this also happened in the 32-bit version and in Vista 32, which should be supported.
why is PT8 "seeing" an alt-down, but apparently not "letting go"? this has happened with 3 different keyboards in Vista and Win7, so it's got to be a PT bug of some sort. It also happened with absolutely no plugins installed whatsoever, so it's not a plugin issue. Quote:
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6 |
Re: The description for Event ID 0 from source digiSPTIService cannot be found
Dare I point out that no version of Windows 7 is supported or qualified yet?
I'll see if I can find some time to look into this, in any case... |
I realize that, but as I said, this also happened quite often in Vista 32-bit, so hopefully you can find something!
I dont know about the alt key issue but I do have events in my log similar to the one discribed above.
My profile has my DAW specs but I'm running XP sp3 with LE 7.4 cs8. I also had the events showing up when running LE 7.3. I have no plug-ins installed. It seems to be writing this event everytime I open ProTools. |
What is digiSPTIService.exe? | jbr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-08-2010 07:23 AM |
1706 no valid source could be found | black baron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-01-2008 07:29 AM |
WHAT IS DigiSPTIservice ??????????? | Jim Casey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2007 09:41 PM |
Lately as I exit PT I get this error - digiSPTIService.exe - | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-30-2007 02:31 PM |
digiSPTIservice.exe - ERROR | benjaminwarren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-24-2007 06:26 AM |
