Protools 11 Midi Sustain Issue
Since installing ProTools 11 on our new studio computer we've had issues with Midi when it comes to sustain. When playing any sort of piano, pad, or organ, the note is cut off when the sustain pedal is lifted, even when the keys are still being held down.
So you can hold down the note on the keyboard, press the sustain pedal, but as soon as you lift up the sustain pedal the note is harshly cut off even though the keyboard key is still pressed. The sustain pedal works otherwise. It will sustain the note correctly as long as you don't let the pedal up while any keys are being pressed. We've tried with multiple keyboards, multiple sustain pedals, multiple virtual instruments, and used both a midi interface and a straight USB connection to the computer. Anybody had the issue? Thanks! Josh 2013 Edition Mac Pro, OSX 10.9.2, Protools 11 |
Re: Protools 11 Midi Sustain Issue
It "should" work better if it's disabled. See also this thread from 2010: http://duc.avid.com/showthread.php?t...t=midi+sustain
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
This blessed me!
I was pulling my hair out trying to figure out how they could update but still have the same issues!!!!!!! Thanks for posting this response! ~BONDED~ www.KEVINBOND.com
www.KEVINBOND.com |
Hello, I am using protools 10.3.10, suddenly the midi session had been doing two very strange things in playback:
1. A looping crackling noise until 2. midi notes get stuck totally - sustaining until I hit stop. Whenever I had this issue in the past I would restart my computer, it would go away, however it is persisting now, and only with this full midi session , I already tried disabling the midi merge. I am on Windows 8.1, using Focusrite 2i2, thanks for your help |
One last thought - are you using a delay plugin? Changing certain parameters on the plugin while playing can cause a sound to stick. |
Sustain issue | mowgli789 | Windows | 14 | 07-19-2012 06:25 PM |
Sustain Issue in PT9 | mowgli789 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-26-2012 04:03 AM |
sustain issue | mowgli789 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-26-2012 04:01 AM |
Sustain and Protools mp 7.4 | Nightworker | Pro Tools M-Powered (Win) | 4 | 06-20-2011 10:42 AM |
Yamaha sustain issue | Nicky2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-18-2010 02:13 PM |
