Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-09-2021, 10:03 AM
Drywsef Drywsef is offline
Default HDX CPU Spikes
Hello all,
Since switching from an HD Native system to HDX, I’ve noticed significantly more CPU spikes when bouncing a mix. This doesn’t make a lot of sense as my System Usage shows a finished mix usage around 20-30%. I have done the Avid recommeneded optimizations and set core affinity to reserve CPU 0 for OS processes. My DPC latency reliably tests under 200us with PT not running. Can anyone help me out with some insights or troubleshooting ideas?
Thanks!
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
Old 02-13-2021, 01:37 PM
Default Re: HDX CPU Spikes
I’ll add that this only seems to happen consistently during bounce to disk. Normal playback and mixing seems ok.
Old 02-13-2021, 02:56 PM
JFreak's Avatar
JFreak JFreak is offline
Surely you can realtime bounce if you can realtime playback without problems
Janne
Old 02-21-2021, 02:23 PM
This seems not to be the case. While I can play back ok, I have to freeze just about every track in the session to get it to bounce properly.
Old 02-21-2021, 02:32 PM
JFreak's Avatar
Do you have the ignore errors during playback checked in playback preferences? Untick that and you know if you can playback you can also bounce
Janne
Old 02-21-2021, 05:38 PM
I have tried both ways. It seems to make no difference.
Old 02-21-2021, 05:39 PM
It even happens when my cpu is at 5%.
Old 02-21-2021, 05:40 PM
JFreak's Avatar
Hard to guess what is the problem but you can always "print to track" id playback works and bounce fails
Janne
Old 02-21-2021, 10:38 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Have you tried deleting PT preference.
If that doesn’t help I would try to remove all the plugins from the plugin folder and intoduce back one at a time.
Old 03-01-2021, 10:11 AM
Thanks, Chris. I will try that and report back.
12.4 CPU spikes with W10 Drywsef Pro Tools 12 12 09-07-2017 11:54 AM
CPU spikes. Help. melloj Pro Tools 12 6 04-01-2017 11:31 AM
Cpu spikes 12.5 stanonbass Pro Tools 12 6 04-03-2016 11:37 AM
CPU spikes with PT8 PTLExp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-04-2009 04:54 PM
If your having spikes..... req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-15-2006 11:25 AM
