Re: "Can't get audio from the drive fast enough" -9073
Ohhh sorry, Time Machine is turned off...not disabled. I'll look into that. Thanks for the tip.
Kontakt and every other sample based program is on my system drive. There's another session, it does not have kontakt or any vst's in it, only audio tracks and it does it all the time, it's a large session though 100 tracks. I held down shift while opening to disable plugins on the afflicted session and it still gave me the error during bouncing. Playback engine is at 1024/4engines/90%/everything else is default. I started a new session and imported session data from the afflicted session and just bounced down the audio tracks and the error still occurred. Quote:
If so then next debug step is to create a new Administrator account on your mac, and log into it and create a test session there. Did that work? Also 4 CPU is too high on a 4 core i5, you should set his to 3. Not that I suspect that causes this problem at all, but I would make the change. I'd also try the limit at 99% once you do that. --- BTW something like ~ 100 tracks of audio starts to get outside the capacity of a single disk spindle (especially over FW) and you need to be looking at spreading such large sessions across multiples drives. Make sure you are doing tested for now with fewer audio tracks (~10 or so?). There is lots of info in the Pro Tools reference guide about how to utilize multiple audio disks, round robin allocation, etc. |
I did have this on one of my drives (oddly enough a Lacie) and it turned out that eventually the bridging chip totally gave up working (i.e. it would no longer connect through Firewire).
This other drive you had connected, is it "PT friendly"? I mean could you try using it as opposed to the Lacie and see if you have the same issue? (just as an experiment).... However what Darryl wrote about limits of a single HDA makes a lot of sense.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Hmmmmm.... I just set it to 3 and 99% and it bounced the track down for the first time ever on the external drive. Just a random occurrence you think?? I've never bounced this track down before, i had to move it to my internal HD to do it... I just bounced it down again with no problems. Hmmm!? Still didn't help the 100 track session but i completely understand what you are talking about spanning over multiple drives. Thanks |
OK so you are on the way. Make sure every last optimization is done. I would personally ditch any Bluetooth keyboard or mouse. And make sure Kontakt and all your other plugs are the latest version (compatible with 9.0.6). And make sure the system is set up properly for Kontakt. NI have optimization instructions for use with Pro Tools.
You may have less IO issues if you 10.x. If you really want to run large sessions with so many tracks I would be looking at something like the dual drive Lacie Thunderbolt box (use each drive as a single drive not RAID) and get the 7,200 rpm version or SSD version. There are also other empty Thunderbolt boxes you can add your own SATA disk(s) to. If doing that I would go with Samsung 840 Pro SSDs. See my other notes on DUC about properly setting up those drives. |
#16
Thanks so much for your input and help.
#17
Spoke too soon happening again, often.... maybe i should look into a thunderbolt drive.... or PT 10??
#18
Download BlackMagic Disk Speed Test (it's free). Maybe there's something wrong with your port/cable. That way we can find out. FW800 should give you 60-80 MB/s read and 40-60MB/s write speed. Anything substantially lower than that points to an issue.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
#19
Just wanted to throw out that I was having the same issue and realized my Firewire drive was 7200 rpm but it was a "green" drive. Bought a wd black and problem solved. Never had a 100 track session going on but 40 tracks yes which is happening to you.
Also, I put the wd in place of the SuperDrive on my MacBook pro which is faster than FireWire. I used the data doubler from OWC for this. I don't know if you can put more SATA drives in your iMac but check it out and get a wd black if possible. Hope you get it sorted, hated this error myself. |
#20
Start by just going over every last optimization and double checking they are all done. How many actual audio tracks do you need in your largest session? How budget sensitive are you? If you can I would go SSD if you can afford it.
I would likely upgrade the disk and Pro Tools. Be careful of your plugin support in PT 11 you need AAX-64 plugins, but you can coinstall 10/11. I would upgrade the external disk first. |
"DAE can't get audio from hard drive fast enough..." | jervin | Pro Tools TDM Systems (Win) | 17 | 06-13-2014 08:04 PM |
"DAE can't get audio from the drive(s) fast enough. Help!! | Schumannz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-22-2012 10:38 AM |
PT 10: "Can't get audio from the drive fast enough" | mr.armadillo | Post - Surround - Video | 18 | 02-03-2012 08:43 PM |
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or | iminzayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2010 10:28 PM |
DAE error -9060 & -9073 "disk frag or too slow" with new LaCie FireWire Drive! | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2003 08:56 AM |
