Bounce problem.... Burns way past highlighted area
Yeah, here's another prob that's just hit me. I've remixed 'One Eyed Gypsy Waltz', and when I highlight from 6 to 166 (the meat of the song), it keeps going past to the end (255, and I still am not sure how to shave unwanted measures at the end of a session).
Any suggestions would be appreciated... Thanks, Roy
rh music |
Re: Bounce problem.... Burns way past highlighted area
Make sure you highlight the timeline and not the waveform. Also the BTD should only go as far as the longest waveform, so you could just delete the waveforms that go to 266 as long as you don't need them.
Apaulos,
Thanks for trying... But, yeah, I'm doing the timeline. It's weird, I've done this a thousand times(well,ok...), but I have 'Low latency' off(probably irrelevant for this prob), and I've tried several variations of highlighting lengths (a few measures more or less on each end). But, each time it insists on rolling an extra minute or so past the end of the highlighted area. So, sheeshter...... Can't figure it out.
rh music |
I tell you guys, I must be losing it. I figured out what I, me, myself was doing wrong. I won't go into it. Suffice to say, it was pretty stupid, but the problem is solved.
Digi, please delete this at your convenience. Thanks, Roy
rh music |
.wav bounce burns to disc with errors | Defekt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-15-2010 05:38 AM |
Bounce to disk running longer than highlighted | mikewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-05-2010 01:25 PM |
Play a highlighted area | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-02-2007 04:44 PM |
Playing audio "within" a highlighted area | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-14-2006 03:42 PM |
doing a punch-in on a highlighted area??????? | woodbeatz | Tips & Tricks | 1 | 03-22-2004 04:55 AM |
