How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Additional Resources
Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-09-2018, 03:46 AM
Raoul23 Raoul23 is offline
Default Preamp and SM7b
What preamps are people using with their SM7b? Iím using a liquid channel set to the 1073 emulation. I find itís very noisy. Think I will try some other emulations in a couple of days just thought Iíd see what people here were using.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-09-2018, 03:55 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Preamp and SM7b
That's strange, i found the 7B to be fairly quiet. the original 7 was a noise monster. I always used the 7 and 7B close up on mainly loud sources, vocals / guitar cabs.
Ive used it through the Groove Tubes Vipre and also worked well through an Aphex 207 tube pre.
Incidentally Bruce Swedien MJ's engineer always said the original sounded better
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 01-09-2018, 03:58 AM
Iím giving it about 50db of gain on the liquid channel. If I add some top and compression the white noise is quite prominent on the recorded track when nothing is happening
Raoul Crane
Old 01-09-2018, 04:28 AM
amagras amagras is online now
Maybe you are too far from the mic, remember the sm7b is a dynamic not a condenser. Just guessing...
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
Old 01-09-2018, 04:30 AM
Stig Eliassen's Avatar
I use it with the Portico 5012. It needs a good amount of gain, but haven't heard any noise that bothered me. What are you recording?
Pro Tools|HDX 2018.3 | Logic Pro X | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5
Old 01-09-2018, 04:36 AM
Iím recording a rock vocal so quite loud. When the track is soloed itís quite prominent only when the vocalist is not singing. My vocal chain is
1073
1176 with about 2-3db on loudest parts
Waves SSL channel in pro tools and sometimes a bit of waves API aswell
Raoul Crane
Old 01-09-2018, 05:06 AM
Drew Mazurek's Avatar
You could try a CloudLifter although I've never needed one with my 7B.
Maybe it's the Liquid Channel? Do you have another pre to try?
www.drewmazurek.com
Old 01-09-2018, 05:08 AM
Iíve thought that?? The 1073 it emulates is from the 70ís so maybe itís emulated the noise also. I think Iím going to try a few different emulations see if itís any different
Raoul Crane
Old 01-09-2018, 06:12 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by crizdee View Post
... the original 7 was a noise monster...
... well, a bit more self-noise than I personally had a use for. I owned 4 original 7's, and finally sold them.
Desktop: Win 7 / GIGABYTE GA-X58A-UD3R / i7-930 / 12GB / 3 int WD Black / PT 9.0.3 / Focusrite LS56
Laptop: Win 7 / HP ProBook 4730s + SIIG FW / i7-2630 / 8GB / int Samsung SSD / PT 9.0.3 / Focusrite Pro 40
Info/Services link
Old 01-09-2018, 06:38 AM
1073
I see. That's weird, I think. The SM7B is not my go-to vocal mic, but the handful of times I've used it has been on mellow vocalists with strong S's.
11 Rack & SM7B notr2d2 Eleven Rack 11 09-19-2013 03:43 PM
Hiss when using m box pro 2 with shure sm7b heyitskeith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-08-2010 12:22 PM
Using outboard Preamp/Bypassing Mbox2 Preamp KennyC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-10-2007 12:00 PM
Studio Projects VTB1 preamp vs ART TPS-II preamp?? ESR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-28-2004 09:23 PM
I'm torn.. Digi001 with better preamp or Digi002 with cheaper preamp/future upgrade Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-05-2003 11:22 PM
