Old 01-07-2018, 10:12 PM
DBK DBK is offline
Default Having trouble determining this tempo
I keep landing on 52.5
Do you think its 52 or 53? OR do you think it's 105? I know 52.5 IS 105 essentially but I'm going to be increasing the tempo to try getting it to 120bpm so it does make a difference, I either need to raise it by 8 or 15. (or 8.5 or 9 but you get the point)
So, 52, 53, 105?
I think the Keys Dm, just trying to stick down a tempo.
https://www.youtube.com/watch?v=-LMFcpw6FXo
Old 01-08-2018, 07:32 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Default Re: Having trouble determining this tempo
If the goal is simply to increase the tempo, the “actual” tempo doesn’t matter, just increase the tempo to taste. The tempo will matter, of course, if you want to track with a metronome. But even with tracking, you may want more subdivisions of the beat for accuracy. I’d assess the tempo as being in a slow 4/4 with quarter notes in the 52-53 range. The songwriter may argue that the meter is 8/8, and then the only thing that changes is the silent counting of the musician, and the time signature on the lead sheet.
Edward
Old 01-08-2018, 01:28 PM
DBK DBK is offline
I guess the originally was recorded in 105 so when I was tapping 52.5 that was right, I was just wrongly assuming that I was half a bpm off while tapping instead of the fact I was just tapping in half time.
Old 01-08-2018, 02:01 PM
octatonic octatonic is offline
As a drummer I'd count that at 52.5, not 105.
If I needed to fit it into a DAW incapable of doing 0.5 graduations of BPM then I'd input 105 but it isn't counted at that tempo.
If you are increasing the tempo to 60/120 then I'd definitely do it at 60bpm.
Something you might not know is that drummers often count using a double definition grid, so when you are hearing something at 60bpm I will be counting 32nd notes- my grid is twice the definition of the feel of the music. It is done to have a really good sense of note placement.
If you are trying to count something like that at 120bpm and using a 32nd note grid it would be totally OTT.
So circa 60bpm works much better in this instance.
having trouble detecting tempo lucidlife Pro Tools 12 7 02-23-2016 03:14 PM
Trouble with tempo changes mid-session caulds989@mac.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2010 03:45 PM
Trouble with tempo mapping mpeddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-13-2009 09:26 AM
Determining tempo of song in 7.4 a.q.s Pro Tools M-Powered (Win) 3 07-12-2008 03:09 PM
Tempo Trouble protoolsjimmy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2007 02:27 PM
