Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-31-2017, 09:39 PM
unkJE unkJE is offline
Default blow that dust right off the fans
… give the screens a clean
…. slide your computer into 2018 with a bit of blow and wipe
Click image for larger version
Name:	blow that dust right off the fans.jpg
Vanilla 2018.12/HD 11.3.2 & 10.3.10 - Studio One 4 Pro - Win7 64 Ultimate – Lenovo W520 ThinkPads (427637U & 4282-UN7) & 433830U Docks – Samples & Songs HDDs - Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32 - Champ 12 - Rode NT2-A, SM57
Old 12-31-2017, 11:03 PM
Default Re: blow that dust right off the fans
i haul my system out to the garage and use the air compressor! I don't have time for those little cans to blow some surface dust off and into my other gear!!! ;-)
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 12-31-2017, 11:46 PM
Sardi Sardi is online now
You need to be VERY careful with an air compressor due to the pressure and also the fact that there is water in the air. I only ever use mine to blow the exterior, never inside a unit.
Those small cans, whilst being a rip off, don't normally have that issue and are designed to be used inside cases etc.
Just an FYI. Would hate for you to accidentally damage your gear.
Old 01-01-2018, 03:03 AM
amagras amagras is offline
Vacuum cleaner here but those little cans look like fun too
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
Old 01-01-2018, 06:21 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
I use a small shop vac. I have one that lets you connect the hose to the exhaust port on the vac so it blows air out rather than sucking it in when used in the normal mode. I try to avoid cleaning out the case when it is humid, because as said above, there can be moisture in the air. I will test the conditions by blowing some air on my hand prior to using the air to clean out the case.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Pro Tools LE 7.4cs10, Windows XP Home SP3, AMD Phenom II 1045T Processor, Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 01-01-2018, 08:51 AM
Drew Mazurek's Avatar
I've had one of these for years.
https://www.amazon.com/3M-497AJM-Por.../dp/B00006HR5F
www.drewmazurek.com
Old 01-01-2018, 10:03 AM
Moisture I live in the desert! and don't store the compressor pressured. Even the cheapest compressors have valves to control the pressure. After 20 years and far more systems than I could count, I think I am ok
pro-tools-pc.com
Intel I7 6800k
Win 10
Old 01-01-2018, 10:15 AM
I just put it all in the back of a pickup truck and drive thru the carwash.....
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 01-01-2018, 11:24 AM
Fair enough.
Old 01-01-2018, 11:50 AM
john1192 john1192 is offline
thats the difference between a PC and a MAC .. the MAC needs the Expensive WAX job !!!!
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
A few Dave Mathews fans may not be fans after... Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 08-26-2004 05:19 AM
will my G5 blow-up if i do this.... GKB Pro Tools TDM Systems (Mac) 3 12-22-2003 11:10 PM
Fans(or one time fans) of the band L.I.V.E. Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 06-06-2003 02:54 PM
Firewire Drives...Fans or No Fans? Don Geppert Pro Tools TDM Systems (Mac) 13 02-23-2003 10:28 PM
SCI 2.04...blow it up my #%@$^ tbo Digidesign Hardware & Software 2 09-12-1998 01:09 AM
