Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 03-25-2010, 07:21 PM
TaylorT TaylorT is offline
Default Volume low when recording with Shure SM58 mic
Hey. I recently just bought a new microphone, the Shure SM58. I'm currently looking at using it for singing in my home studio. I use Pro Tools LE with the M-box and i plugged my chord into the mic then into the proper place in the back of the M-Box. I have the phantom power 48v turned on and the input at a reasonable level.
The problem is this: when i go to record vocals the volume is soooo low!! I've turned the input all the way and its still low. Granted I can mix it and compress it but it still has a low volume with the overall music. I didn't experience this with my last mic i was using. I don't know if anyone can help with this problem, but id be more than happy to here your responses! Thanks
Old 03-25-2010, 07:46 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Volume low when recording with Shure SM58 mic
First, an SM58 is a dynamic mic, so it does not need phantom power. Phantom power probably won't hurt it, but it's not doing anything so turn it off.
That being said, dynamic mics tend to have less signal level coming in than a condenser mic(condenser mics are mics that require phantom power). An SM58 is typically used more in live situations than studio situations. It's going to work best with louder source material, and/or being closer to the sound source. So if you're using it the exact same distance as you did with a condenser mic from the same source material(your voice, or your talent's voice), that's why your levels are lower.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 03-25-2010, 07:47 PM
The Weed's Avatar
The Weed The Weed is offline
This won't fix the low level, but the Shure is a Dynamic mic, so it doesn't need any phantom power. It shouldn't affect or harm the mic to leave it on, but since it's not necessary...
Just a thought, but do you have the input set to mic or line?
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
The Weed's Avatar
Too slow for John!
Old 03-25-2010, 07:59 PM
Are you using a regular mic cable(XLR at both ends)?
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 03-25-2010, 08:19 PM
sunburst79 sunburst79 is offline
While they may not be as sensitive as a condenser a SM57 or SM58 has a very healthy output level. As much as anything else it sounds like you may have a bad mike. I had a bad brand new SM57 once- it can happen.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 03-25-2010, 08:35 PM
Thank you guys for the help.
Old 03-29-2010, 02:36 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Have you tried running it though a external preamp ?
That should help.
Old 03-29-2010, 02:48 PM
necjamc necjamc is offline
Other than all the other suggestions here, have you tried turning the input gain all the way up on the m-box? One thing with dynamic mics to consider is that they tend to pic up the source (your voice) when very close to the screen but drop off very fast as you move away. The chances of the mic being bad, although possible, are very slim. Out of about 30 mic's my band, myself and a few friends have purchased, including beta 58's, sm57's and sm58's not one has been bad.
Also, make sure like someone else's comment, that it is a xlr to xlr cable. That will make the biggest difference. I don't know about the m-box, but a lot of the interfaces seem to have very low input volumes. Crank it up!
Old 05-15-2014, 02:23 AM
DJ Bechara's Avatar
DJ Bechara DJ Bechara is offline
Just a thought .... can the Shure SM58 be connected to a line input since it's a dynamic mic or it has to be connected to a mic pre ??
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
macOS 10.13.3
Pro Tools 2018.4
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack SPDIF/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad Thunderbolt
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Ibanez Pedals/Fender Strat
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840
Playback volume much louder than recording volume BinkBonk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2008 04:21 PM
Recording Bass with Shure KSM 44 Room24Prod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-06-2004 06:08 PM
Sm58 on drums? hylsan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-07-2004 09:38 PM
do shure sm 57s work real good for recording drums skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-06-2003 06:21 PM
SM58 as a vocal mic vbalian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 04-22-2001 12:23 AM
