EQIII CS2 Not recalling Q correctly.
Several instances of EQIII in a session I'm working on are not recalling their Q factors correctly.
The instances are of the 1band type, I haven't had time to see if this happens with 4band and 7band instances yet. Here is one example, Q=4.00 F=166.5dB Gain= -4.5dB When the session is reopened after saving, the Q factor is 0.57 ( the frequency and gain are correct ). I only noticed this happening after I installed the most recent CS update. Bearing this in mind I decided to trash EQIII from the plugin folder, reinstall the original EQIII release and update to the CS1 fix. This WORKED. It recalled the Q settings correctly... Phew! I'm running Protools 6.9LE on Mac OS 10.3.9. I realise this OS is not officially supported, could this be the cause ? |
Re: EQIII CS2 Not recalling Q correctly.
10.3.9, while problematic in other areas, should not have any bearing on the issue you were having.
So everything is working correctly now, yes? |
Yes, everything seems fine now I've reverted to the CS1 update.
I've been working all day since I found the problem this morning and haven't noticed it happen since. I don't use latch mode that often when automating, so hopefully I won't miss the fixes in CS2 that much. |
same on my system:
eq III 6.9cs2: q-settings are not recalled correctly. eq III 6.9cs1: works fine.
digi 002 rack MacPro 2 x 2.66 GHz Dual-Core intel Xeon 5 GB RAM OS 10.4.10/PT LE 7.1.1cs2 |
Loom not recalling saved parameters correctly | Eric Lambert | AAX Plug-ins | 20 | 12-12-2013 04:51 PM |
EQ3 Not recalling/saving settings | slaterweezer | Pro Tools TDM Systems (Mac) | 0 | 04-09-2012 10:42 AM |
Sound Toys not Recalling | ChsGlvr | Pro Tools TDM Systems (Mac) | 1 | 08-28-2009 04:27 PM |
Is there a Bug® with recalling zoom settings?? | Bushpig | Pro Tools TDM Systems (Mac) | 11 | 07-13-2009 02:49 PM |
recalling memory locations | pauleddy2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-11-2002 12:50 AM |
