Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #71
Old 12-26-2019, 05:18 AM
johnnyv johnnyv is offline
Default Re: 2019.12 Discussion
Originally Posted by TNM View Post
Through Octatonic's gracious testing for us over at GS
Can you provide a link to Octatonic's testing at GS?
  #72
Old 12-26-2019, 02:59 PM
Carl Lie Carl Lie is offline
Through Octatonic's gracious testing for us over at GS, it has pretty much been confirmed now that the mac pro 16 has a clocking issue.. You may want to check that out and make sure you are OK with it :)
Basically, heavily loaded workflows effectively remove all turbo boost and in certain situations can drop below base clock. it's not thermals as thermals are outstanding when it happens (in the 40's!) so I believe it to be a power delivery issue. Hopefully it can be fixed with a simple EFI update, if it's not by design.
Thanks for the heads up. I like to wait a while before I jump so I can understand all the ins and outs. Not in a rush but plan to move at some point next year.
C
PT 2019.12 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #73
Old 12-26-2019, 03:10 PM
uptheoctave uptheoctave is offline
Starts around here:
https://www.gearslutz.com/board/musi...c-pro-114.html
  #74
Old 12-26-2019, 03:11 PM
C
I considered waiting but I've been waiting for Apple to make a Thunderbolt enabled tower since 2012 so jumped early.
On the whole it has been brilliant.
I've got HDX working on it too.
  #75
Old 12-27-2019, 07:16 AM
I believe it's an excellent machine. We'll find all sorts of little things out over the next few months.
What were you using prior to this? I use an older 12 core cheese grater. Still works but....
C
  #76
Old 12-27-2019, 11:58 AM
fourthtunz fourthtunz is offline
Originally Posted by audiobob View Post
You can install 2019.12 on a Mojave machine and not have to worry about the 32/64 issues. You don't need Catalina to run it. I did on a 10.14.6 Mini and it's working fine so far. Have both 2019.10 installed as well just in case.
How is 2019.10 and .12 compared to .6 on the mini?
I have the same OS and the mini...
Haven't run Protools in a while and wanted to record some stuff today and didn't want to have problems.
I tried to upgrade my ram from 8 to 32 to today but the torx bits from amazon were **** so I'll have to wait ;(
Thank you!
  #77
Old 12-27-2019, 02:00 PM
Thank you!
They bolt the ram in in Mini's now? No more spread the clips and out they come?
Jack
QAPLA!
  #78
Old 12-27-2019, 02:31 PM
Sardi Sardi is offline
Pretty much.
Installing RAM modules on the new Mini essentially involves pulling apart the entire machine. Unfortunately, it’s nothing like the old Minis where it was a 2 min job.
  #79
Old 12-28-2019, 11:33 AM
drh1's Avatar
drh1 drh1 is offline
2019.12 has been stable so far with brief testing.
http://douglashood.zenfolio.com/
MSI X99A SLI Plus LGA2011, i7 5930 3.5 GHZ 6 core 12 threads, Kingston HyperX Fury 64GB DDR4 2400MHZ, NVIDIA Quadro K2200, LG 16x Blu-ray writer, Samsung 850 Pro 512 GB SSD for OS, Samsung 970 EVO Plus NVMe M.2 1 TB SSD for samples, four WD Caviar Black 1TB SATA 3 6Gb/s 7,200 RPM drives (audio, samples, video x 2), EVGA Supernova 750W G2 PSU, Corsair Cooling Hydro H100I V2, W 10 Pro, 4 TB WD USB3 external backup, PT 2020.5, IK Sampletank 4 Max, AIR IEP, Wavelab Pro 9.5, RME Fireface UFX w USB2 connection.
  #80
Old 12-29-2019, 07:30 AM
audiobob's Avatar
audiobob audiobob is offline
No, ram is not hardwired into the Mini, but like Sardi said above it's not a simple process getting to it. I installed 32 gigs. Once you get to the ram it's simple....it's getting there that's a bit of a challenge. I followed this guide:
https://www.youtube.com/watch?time_c...ature=emb_logo
Pro Tools 2019.10 Discussion TOM@METRO Pro Tools 2019 94 12-05-2019 01:51 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
The -20 dB discussion Syncman Post - Surround - Video 10 11-12-2003 09:53 PM
