Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-31-2019, 03:12 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Default 2019.5 Manual punch in not functioning anymore?
Just something I have noticed since updating to 2019.5 when manually punching in on a track.... I used to be able to arm the track, hit spacebar, then at the preferred moment hit the “3” key on the keypad section of my keyboard to throw the track into record mode..... but that doesn’t happen anymore.
Still appears you can jump into record mode on an record armed track using the above mentioned “3” key just can’t have the transport in motion when you do.
Is this a bug? Wouldn’t mind it being fixed if it is
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2019.12-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 05-31-2019, 03:54 AM
Drew Mazurek's Avatar
Default Re: 2019.5 Manual punch in not functioning anymore?
Turn on Quick Punch.
www.drewmazurek.com
Old 05-31-2019, 09:03 PM
xrekcor's Avatar
Thanks Drew
Not sure why they had to change that but as long as it works. Usually only use quick punch for when I want to do a once off auto punch.
Rob
Old 05-31-2019, 09:52 PM
Prosound Prosound is offline
Pro Tools has been functioning this way for as long as I can remember. It sounds like Quick Punch just got switched off when you upgraded to 2019.5 and you weren't aware. Definitely not a bug.
Old 05-31-2019, 10:25 PM
xrekcor's Avatar
My prob wasn’t actually quick punch... but thanks for your input anyway.... besides I reckon I would remember the “P” on the record enabled button if what you are suggesting was the case....
Rob
Quick punch.... can't hear track audio until I punch in stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-31-2017 02:11 AM
How can I set keyboard on MacBook Pro for Manual Punch In? Squid Vicious macOS 1 01-16-2013 11:06 AM
HD 10 No Boxed version no manual where can I get a manual HD10 phatbeatstudio Pro Tools TDM Systems (Mac) 4 12-26-2011 01:01 AM
Quickpuhch/automatic punch out - Paper Reference Manual Available? jneher Pro Tools 9 3 02-20-2011 06:58 AM
