Old 03-16-2015, 12:18 AM
Karel Noon Karel Noon is offline
Default Fine control disables vca spill?
Hey people,
I noticed this weekend that while I am in fine control mode on the S3 I cannot go into vca spill mode, is that behavior planned or is it a bug?
Or is there some other reason this is not possible?
Old 03-16-2015, 03:43 PM
Mike Z's Avatar
Mike Z Mike Z is offline
Default Re: Fine control disables vca spill?
Hi Karel, I'm not seeing this problem. Can you provide more detail?
Here's what I did:
Assign some channels to VCA 1
Assign VCA's to global section
Double press control button to latch Fine mode
Double press Sel button for VCA 1 to spill the VCA members
result - VCA members spill normally
Thanks, let me know if this works for you or what you are doing differently.
-Mike
Avid Live Sound Support
Old 03-17-2015, 03:29 AM
i assigned some channels to a VCA
I assigned that VCA to the User layer
I Double tapped fine to latch it
Double tapped Sel. Next to the corresponding VCA fader
No vca spill
As soon as i got out of fine mode it worked as it should
I can retry and verify this evening with a new show file
Old 03-17-2015, 02:07 PM
Mike Z's Avatar
ok, I see the same issue now when attempting to spill from the User bank in fine mode.
Let me investigate further and I'll let you know.
Old 03-18-2015, 12:50 AM
Thank You for the help.
Old 03-18-2015, 09:36 AM
Mike Z's Avatar
You're welcome!
We've confirmed and logged the issue and hope to have it fixed in the next release. Thank you for bringing it to our attention.
Best,
-Mike
Digi 002 via firewire-thunderbolt to Macbook - audio is fine but no control of 002 BMJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-25-2013 03:00 PM
Fine plugin control Moviesound macOS 1 09-15-2012 09:09 AM
can you spill the playlist in the control surface????? DHG MUSIC Pro Tools TDM Systems (Mac) 12 12-30-2008 08:06 AM
VCA spill , ala D control on a command 8? cajonezzz ProControl, Control|24, Command|8 0 09-28-2007 12:02 AM
Amplitube and T-racks EQ less fine control?? Hekler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-20-2004 09:55 PM
