Old 02-03-2006, 05:51 PM
thebends9 thebends9 is offline
Default External Drive Problem..Please Help
Hey Guys,
I bought a Seagate 300 GB extrenal drive to record my audio onto. When I go to open a session on this drive it says "This session is saved on a volume set to Transfer only. Se the volume in question to playback or record in the workspace.
When I go into workspace and try to change it to record onto it says sea_disk cannot be designated as an audio record volume because it is not a valid audio volume.
Can anyone with an external drive give me a little bit of help. Id like to record something ton ight. Thanks!!
Old 02-03-2006, 06:20 PM
James Junior James Junior is offline
Default Re: External Drive Problem..Please Help
Hey I had this problem as well. Things will be ok. You are going to need to reformat your hard drive through the program disk utility which is in the utilities folder. Once you open the program your hard drive will show up on the left side of the window. Select your hard drive and then click the tab partition. Choose how many sections(partitions) you would like to split your hard drive into. Then select the format as Mac OS Extended (non-journaled). Then click partition and once that process is finished you should be able to designate your drive as a record drive. I hope it all works out for you
Old 02-03-2006, 06:47 PM
Thanks, I dont need more than one partition on that drive correct?
Old 02-03-2006, 07:28 PM
Fixed, thanks
Old 01-31-2007, 11:14 PM
Hear Me Shimmer Hear Me Shimmer is offline
I'm trying to do the same thing. When I try to reconfigure my external for OS X Extended (Journaled) it says that it "Failed. Could not dismount drive." Anyone encountered this one?
1: PowerBook 1.67 GHz G4. PT LE 7.1.2
2: Mac G5 w/ dual 2.3 GHz. PT LE 7.3
Help with an external drive problem. peht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 05-05-2010 11:49 PM
External Hard Drive Problem P Mackey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-15-2007 10:38 AM
External Hard drive problem Fladlien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 05-11-2005 03:07 PM
External hard drive problem splendidmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-29-2005 12:35 PM
Problem w/ external FW drive Stage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 06:00 PM
