Old 02-14-2020, 10:57 AM
Lynn Gräber Lynn Gräber is offline
Default OK and Cancel Softkeys
These working for anyone else in 20.1?
Old 02-14-2020, 11:19 AM
XJENSEN XJENSEN is offline
Default Re: OK and Cancel Softkeys
I also noticed weird things going on with the soft keys today.. Some of them weren't working and began flashing and stuff. Didn't dive into it since I don't use them that often anyway.
Old 02-17-2020, 11:44 AM
Ellis Beckwith Ellis Beckwith is online now
Cancel / OK work as expected everywhere I've tried except that in Menu>File>Save the OK key doesn't flash and doesn't initiate a save. But, tapping again on the Save key does save the file. don't recall whether this worked this way before the update because I always use the small Save key at the bottom of the screen and just tap it twice.
Ellis Beckwith
iMac (mid 2011), Intel Core i5 2.5 GHz, 32GB; Samsung 500Gb SSD, PT 2019.5.0, Avid Control; M-Audio Oxygen 25, Faderport 1
Old 02-17-2020, 12:11 PM
I am talking specifically with bounce to disc and bounce track. Hitting OK does not initialize bounce from the dialog. I have to hit enter on the keyboard.
Also, my top layer of softkeys at the bottom of the Control app are messed up. The text is from the memory locations page, but its top level commands.
Old 02-17-2020, 06:37 PM
barden barden is offline
Lynn...
I can report that my Dock surface OK and Cancel buttons are working as predicted. Same for the OK and Cancel in the Control App (on-screen softkeys) and their corresponding Dock surface soft keys.
Dock, S1, EuControl 20.1, PT2019.10, latest App versions, latest firmware, MacOS 10.14.6.
~Barden
Old 02-19-2020, 05:43 AM
docric docric is offline
Originally Posted by barden View Post
Lynn...
+1
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.6
PT 2019.12.0 Ult.
Burl MS / PT Dock/ Avid S1/2x iPad Air2/ Avid|Control
Old 02-28-2020, 07:27 AM
I still have not figure this out. Anyone have any insight?
Old 03-03-2020, 05:39 AM
Barranca Barranca is offline
Lynn, this might not apply to your situation.....but,,,,, I had trouble with OK & Cancel keys for several days/ reboots. I got lucky, I don't know 'how' it happened, but one day an apple osx window popped up. Now mind you I did nothing different that I hadn't done a MILLION times previous, but the osx window popped up, the one where you have to go into System PREFs and implicitly check the box that you want to give avid control permission to make changes/control osx....darn the name slips my mind...once I checked the box and rebooted BOOM OK and cancel started working..sorry I'm not in front of my computer. I will try and remember to look and update back here. Again sorry if you already tried this.....(I think it is called 'Accessibility'
Alec
iMac OSX 10.14.6
Pro Tools 2019.12
Avid Control 20.1.0.8
iPad 6th Gen ios 12.4.1
2-Artist Mix soon to be 2-S1's
Logic Pro X
Old 03-10-2020, 10:35 AM
Alec
did you ever look this up. I looked under the security preferences and everything seemed to be in order.
Edit: Nevermind, I found it! PTL. Security prefs, Accessibility, make sure Pro Tools is checked.
Gosh man, the security hoops are getting kinda ridiculous.
Old 03-10-2020, 11:30 AM
Southsidemusic's Avatar
Thank Apple for those hoops.
Best Regards
Christopher
South Side Music Group
WEBHOME
Dock softkeys (possible bug) bewk Avid S1, S3, Dock and Control 13 02-14-2020 06:28 AM
S6 Softkeys PatrickCusack Avid S6 4 05-23-2018 04:32 AM
What is best way to cancel the PC NOISE? akhafaji Pro Tools 10 23 08-22-2012 05:19 AM
C|24 and PTHD softkeys fakir_cz ICON & C|24 4 12-01-2011 06:54 PM
Can't cancel bounce DontLetMeDrown Windows 21 04-26-2011 10:52 PM
