PT Freezes ... too often! (MP9,FTP, Win7 64)
Hey Guys!
I bought Pro Tools MP 9 a while ago and im really excited about it. Unfortunately it is just doing one thing: crashing all the time! Ive optmized my PC as described in the Guide but everytime I start PT or try to open a Session is a 50/50 Chance that it freezes. (Even excessive praying while loading didnt seem to help! ) Either it freezes before the startup screen (where you can select a session or crwate a new one) or while loading a Session. Pressing "Shift" to open a Session with all Plugins deactivated seems to help sometimes. But not if there were no plugins in the session or if it freezes before i am able to select them. I use MP 9.0.5, the latest FTP Driver (6.0.7 or so) and Windows 7 Home Premium 64bit. Any help is greatly appreciated, as for me PT is nearly unusable. The Sandra report looks like this (unfortunately in German): SiSoftware Sandra System Modell : Sony VPCEB1M1E Arbeitsgruppe : WORKGROUP Hostname : Benutzer : Prozessor Modell : Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz Geschwindigkeit : 2.13GHz Kerne pro Prozessor : 2 Einheit(en) Threads pro Kern : 2 Einheit(en) Typ : Mobile, Dual-Core Interner Datencache : 2x 32kB, Synchron, Write-Thru, 8-weg Satz, 64 Byte Zeilengröße, 2 geteilte Threads L2 Cache : 2x 256kB, ECC, Synchron, ATC, 8-weg Satz, 64 Byte Zeilengröße, 2 geteilte Threads L3 Cache : 3MB, ECC, Synchron, ATC, 12-weg Satz, Exklusiv, 64 Byte Zeilengröße, 16 geteilte Threads System Mainboard : Sony VAIO System BIOS : AMI (OEM) R0300Y8 07/20/2010 Bus(se) : PCI PCIe IMB USB i2c/SMBus MP Unterstützung : Nein MP APIC : Ja Gesamtspeicher : 3.86GB DDR3 SO-DIMM Chipsatz Modell : Sony Core (Arrandale) Mobile DRAM Controller Front Side Bus Geschwindigkeit : 2x 2.4GHz (4.79GHz) Gesamtspeicher : 4GB DDR3 SO-DIMM Kanäle : 2 Speicherbusgeschwindigkeit : 2x 10.15GHz (20.3GHz) Speichermodul(e) Speichermodul : A-Data EL7YG1B1672ZG 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Speichermodul : A-Data EL7YG1B1672ZG 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Grafiksystem Grafikkarte : ATI Mobility Radeon HD 5650 (400 SM5.0, 1GB DDR3 128-bit, PCIe 2.00 x16) Grafikprozessor Compute Shader Prozessor : ATI Mobility Radeon HD 5650 (400SP, 1GB DDR3 128-bit) STREAM GP-Prozessor : ATI Mobility Radeon HD 5650 (400SP) Physische Speichergeräte WDC WD5000BEVT-26A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (C:) (D:) RICOH R5C592 : k.A. (E:) RICOH R5C822 : k.A. (F:) Optiarc DVD RW AD-7700H (SATA150, DVD+-RW, CD-RW, 2MB Cache) : k.A. (G:) Logischer Speichergeräte System Reserved : 100MB (NTFS) Daten (D:) : 98GB (NTFS) @ WDC WD5000BEVT-26A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Festplatte (C:) : 300GB (NTFS) @ WDC WD5000BEVT-26A0RT0 (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Recovery : 11GB (NTFS) Auswechselbares Laufwerk (E:) : k.A. @ RICOH R5C592 Auswechselbares Laufwerk (F:) : k.A. @ RICOH R5C822 CD-ROM/DVD (G:) : k.A. @ Optiarc DVD RW AD-7700H (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherie LPC Hub Controller 1 : Sony HM55 LPC Interface Controller Audio Gerät : Sony P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Audio Gerät : Sony Redwood HDMI Audio [Radeon HD 5600 Series] Audio Codec : ATI (AMD) HDMI Audio Laufwerkscontroller : Sony P55/PM55/3400 4 port SATA AHCI Controller Laufwerkscontroller : Sony PCIe SD/MMC Host Controller Laufwerkscontroller : Sony PCIe SD/MMC Host Controller USB Controller 1 : Sony P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Sony P55/PM55/3400 USB2 Enhanced Host Controller System SMBus Controller 1 : Intel ICH SMBus Drucker- und Faxgeräte Drucker : HP Photosmart C4600 series (1200x1200, USB, Farbwiedergabe) Drucker : Microsoft XPS Document Writer (600x600, Farbwiedergabe) Fax : Microsoft Shared Fax Driver (200x200) Peripherie Netzwerkdienste Drahtlosadapter : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Energieverwaltung Stromnetzstatus : Angeschlossen Batterie Nr. 1 : 66% Betriebssystem Windowssystem : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 |
Re: PT Freezes ... too often! (MP9,FTP, Win7 64)
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
hey, thanks for the quick replys.
I am already running PT as Administrator (this was part of the Widnows Optimisation Guide). I only have a very slow External Hard Drive so I'm recordng to a second Partition. Btw: Is USB 2.0 even fast enough to record flawless on an external HDD? After formatting and reinstalling my system Pro Tools worked very well today. But I dont have any Midi Hardware or Plugins installed or used ... (I use an MPD24, the Komplete Players and FL Studio via Rewire) I'll give it some trys as i dont expect my problems to be solved yet. And it was not the first time i resetted my whole system just for Pro Tools. Until then, any hints and tips are greatly appreciated ;-) |
As i wrote it in my first post, PT and the FTP are up to date, so is my windows.
IE 9 is NOT installed (i read somewhere that it can cause problems with the FTP) |
Well, finally NOT TOUCHING ANYTHING AT ALL while Pro Tools loads up
combined with A LOT OF PATIENCE seems to be THE insider's tip for a well working Pro Tools Environment in my Case |
after i sold my PT MP9 I came back to it after half a year and *surprise* i am still experiencing the same problems over and over again.
Crashes, Hangups, Total System Freeze ... how do I find out WHAT the Problem is that causes all these issues? (Every single Program I have on my MAchine works absolutely FINE ... except Pro Tools) System Report is still up to date except the fact, that I doubled my RAM. |
Protools freezes during start-up (freezes after "Dae loaded").. Please help! | andreeaspersson | Windows | 1 | 01-01-2013 04:47 PM |
digi003 factory win7 64 bit freezes or blue screen | hkk009008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-07-2011 09:02 AM |
New laptop-windows freezes when starting a session on win7 64 | reltucdc | Pro Tools M-Powered (Win) | 0 | 10-28-2010 09:55 AM |
Pro Tools LE 8.0.3 + Digi003 freezes with Win7 Pro x64 | Chief Pronto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 53 | 01-10-2010 10:42 AM |
GR4 PT 8.0.1 Win7 | jazzmandan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-01-2009 06:19 PM |
