High Spec PC not coping with simple sessions
Up untill recently I've been running Pro tools of of a laptop and CPU, H/W buffer, and disk speed errors were somthing far too farmilliar.
So I've recently forked out for a new PC that I've put together myself. It has a phenom II X6 3.3GHz proccesser , 2x4Gb RAM and a 64Gb SSD. and I'm running it on Windows 7 Pro 64bit. But now after using the system for just a short period of time I'm getting the old familiar error messages again. I've tried tweaking the H/W buffer, CPU, processor options, only succeeding in triggering one of the alternative error messages. I'm only running 8.0.5 LE and this system should be able to more than handle it, yet it's profforming the same as my old laptop (if not slightly worse) If any one has any ideas/ suggestions I'd be very greatfull. Thanks, Hedley |
Re: High Spec PC not coping with simple sessions
Also I'd like to add that every other aspect the PC is working very well. starting up in a couple of seconds, copying files in the blink of an eye etc. as you'd expect from an SSD/ fast processor.
In a similar boat myself, but with a completely different computer. Without a Sandra report, nobody will have much help to offer.
Help us Help You - READ THIS Before Posting!
Are you recording to a different drive than your system drive? If so, is that drive FW? PT doesn't support working with USB drives. Again, if you are working with a second hd, what is the drive speed? Typical laptop speed drives of 5400 RPM are no good; you need 7200 RPM or better. And no 'green' drives either that allow the drive speed to follow work load or spin down and sleep. Speaking of sleep - don't allow your computer to sleep. |
Oops - just saw the compatibility list for Windows and Avid does say to use USB. I still wonder why that is so. Last edited by musicman691; 12-01-2011 at 01:17 PM. Reason: correcting for bad assumption |
Hi, Sorry for getting back to you so late.
Here is the Sandra Report SiSoftware Sandra Computer Model : OEM To be filled by O.E.M. Workgroup : WORKGROUP Host Name : HedleyKnightsPC User : Hedley Knights Processor Model : AMD Phenom(tm) II X6 1100T Processor Speed : 3.31GHz Cores per Processor : 6 Unit(s) Type : Six-Core L1D (1st Level) Data Cache : 6x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 (2nd Level) Cache : 6x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size L3 (3rd Level) Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 6 threads sharing Computer Mainboard : ASUS M5A97 BIOS : AMI (OEM) 0705 08/22/2011 Bus(es) : X-Bus PCI PCIe USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 8GB DIMM DDR3 Chipset Model : AMD F10 Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1.79GHz (3.58GHz) Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 597MHz (1.2GHz) Memory Module(s) Memory Module : Patriot Memory 1333LLA Series 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory 1333LLA Series 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 810MHz 128-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 810MHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 810MHz 128-bit) Compute Shader Processor : NVIDIA GeForce 210 (16SP 1.4GHz, 512MB DDR2 810MHz 128-bit) CUDA GP Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 810MHz 128-bit) Storage Devices KINGSTON SV100S264G (64GB, SATA300, 2.5", SSD) : 60GB (C:) Seagate ST9500424AS (500.1GB, USB2/SATA300, 2.5", 7200rpm, 16MB Cache) : 466GB (G:) Seagate ST9500325AS (500.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) : 466GB (E:) TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) TSSTcorp CDDVDW SH-222AB (/SATA150) : N/A (H:) Logical Storage Devices Hard Disk : 100MB (NTFS) Expansion (G:) : 466GB (NTFS) @ Seagate ST9500424AS (500.1GB, USB2/SATA300, 2.5", 7200rpm, 16MB Cache) Backup (E:) : 466GB (NTFS) @ Seagate ST9500325AS (500.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) Hard Disk (C:) : 60GB (NTFS) @ KINGSTON SV100S264G (64GB, SATA300, 2.5", SSD) Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (H:) : N/A @ TSSTcorp CDDVDW SH-222AB (/SATA150) Peripherals LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller LPC Legacy Controller 1 : T2 87-21 Audio Device : ASUS IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : ASUS High Definition Audio Controller Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Serial Port(s) : 1 Disk Controller : ASUS SB700/800 SATA Controller [AHCI mode] USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller USB Controller 8 : ASUS ASMedia XHCI Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.8 Performance Enhancing Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Hope that's what you wanted,
also I'm using the one ssd on the pc, no external drives. |
There's part of the problem - you need to get at least one more drive as PT doesn't really support working with just the system c: drive. Partitioning won't help - you need another physical drive.
Price too high for simple changes. Why?? Avid! | Frecord | Pro Tools 10 | 16 | 10-27-2011 07:25 AM |
How are you guys coping without ADC? | chimp3000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-02-2010 07:12 AM |
Split tracks to multiple drives for high density editing sessions? | audiogeekzine | Tips & Tricks | 6 | 06-08-2009 09:06 AM |
A simple way of fixing that high pitched whine for Mbox 2. | Justbleazy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-15-2008 10:21 AM |
Deleting PT Sessions -- Is it that simple? | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2006 02:50 PM |
