Meters won't peak while recording...EVER!!?!??
Hello there,
I am curious why whenever I am recording into pt I can never seem to clip the meter in the pt mixer. Could this be something to do with Mixcontrol (virtual mixer software which comes with the Focusrite saffire 56 interface)? When I look at the Mixcontrol virtual mixer, I can see that loud microphones WILL infact clip into the red, however protools seems to not consider the overdriven distortion clipping. Has anyone else experienced this issue? Thanks in advance UPDATE: http://duc.avid.com/showthread.php?p=2126863 |
Re: Meters won't peak while recording...EVER!!?!??
Never experienced this, are you pre/post fader metering? Do you have any inserts with a limiter active on those tracks?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
My meters are pre fader. No inserts with limiters. Any ideas?
Have you tried it without the Mix software?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
Just had a thought, I don't know if my PT meters peak during tracking because I ONLY use the meters on my mix control during that stage. They are on the a/d stage. If you clip those, I could see why it wouldn't clip in PT. I'll go down and test when my wife heads off in a bit. I can get them to clip but only while mixing...although, it's bad practice to even get close :P
SpinningDisk,
Unless I have been misinformed, it is not possible to use protools with my interface unless I am running this mix control software as a virtual input mixer. |
PT should be the Host. I could be wrong. Someone will chime in.
I'm trying mannnn😊
Chk out my post....bypass mix control
Also try checking ur levels post fader
This is really not relevant as it makes no difference to the input routing INTO protools.
This is not normal for protools faders to fail to show clipping on a recording track. Something is wrong here. |
Peak meters accurate?? | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2006 09:21 AM |
Meters--Peak or PPM? | danika | Pro Tools M-Powered (Win) | 0 | 10-15-2005 12:55 PM |
Meters Peak Hold???????? | tnie | Pro Tools TDM Systems (Mac) | 9 | 05-31-2003 12:47 AM |
Outboard VU/Peak meters ... | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-04-2002 04:12 AM |
peak meters | dellamattia | Digidesign Hardware & Software | 2 | 03-27-2001 01:35 AM |
