Old 04-01-2013, 08:24 AM
M2E M2E is offline
Default TC VSS3/DVR2/MD3 Work on PT 10 HD?
Hello to all.
I was thinking of upgrading but, I still use my TC TDM plugins.
I'm NOT moving to HDX but just updating the software to HD.
Thanks in advance.
Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
Old 04-01-2013, 10:04 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: TC VSS3/DVR2/MD3 Work on PT 10 HD?
TC plugs work with TDM HD 10 but not with HDX (cause they're TDM plugs). Ask TC about AAX versions, please!
Janne
Old 04-02-2013, 08:08 AM
dtmprod dtmprod is offline
yes, I use them all the time in PT10 HD. I usually put them on aux channels that load first when the session boots. That way they grab the 'smaller' chips on the cards. Otherwise you can end up where they just use 50% of the 'larger' chips. That's power that could be used for other plugins. They don't use the DSP sharing protocol that newer plugins take advantage of.
Old 04-02-2013, 10:01 AM
JFreak's Avatar
Yep, you're right.
But if you find out that the plugs allocate "wrong" chips, you can always disable plugins and then re-enable them again in proper order. If you can put plugins in proper slot numbers (for example, all TC plugs in #3 or something) it is easier because you can disable/enable all plugins in certain slot at once.
The DSP Shuffle fuction is pretty good, but it is not perfect. Sometimes you need to do the shuffle by yourself.
Janne
WTB TC CL1B,MD3,Nonlin2,DVR2,Harmony 4 plugins dicky.chan Buy & Sell 2 04-26-2013 08:13 AM
FS: tc electronic DVR2 + nonlin2 TDM, URS BLT eq TDM RTAS AU VST matt_the_manic Buy & Sell 0 04-07-2013 03:35 AM
TC VSS3... very impressive Anibal Pro Tools TDM Systems (Mac) 54 06-18-2010 02:50 PM
TC VSS3 Fixed on PT8 dr sound Post - Surround - Video 0 02-09-2009 08:25 AM
Tc vss3 K.I. Pro Tools TDM Systems (Mac) 1 02-09-2009 06:09 AM
