input monitoring issues
I ran into an issue with my PTS Le system, regarding the input monitoring. I tracked a live band starting with a pilot line (Track). I wanted to do punch in at a spot and discover issues which I am not sure how to get around it. When record is armed I play back the parts to pick up at what ever bar we need to punch in at, and I need to hear the live input too as well as the parts now playing which was recorded, playing back so the musicians know where they are as well as hear . Without hearing the live parts along with the parts playing back. The live part only become active as soon as one hit record, along with the parts playing back, the musicians need to hear the live signal even before recording punch in as well, if I switch the mode then I hear the live parts, however I need to hear the play back at the same time to pick-up from there. I hope I made it really clear.
Re: input monitoring issues
Its an option called input monitoring/auto-input.
You have it on auto-input at the moment. You require input monitoring. The short-cut to toggle it is: alt + k |
Re: input monitoring issues *DELETED*
Post deleted by andre67
I think I did not make my self clear enough, I know about the input monitoring modes, they do not allow live input monitoring along with playback. If I switch the mode so that I can here the tracks played back then live signal do not come through until I it record. I need to hear live signal with the play back.
But... that is what input-only monitoring mode is for...
The only way to get both is with external hardware monitoring (or duplicating the tracks ) .
The way I would do it is to duplicate the track or just the part you want to punch in and then they can hear it as you punch in on the other track. Since you are recording over the area you want to monitor, I don't know how you would hear and record at the same time on the same track.
I am glad you understand my mail correctly, as some people here are tell me about the obvious for example input monitoring modes which I know about, where as I am saying these mode do not deliver what I need as they have restriction when it come to live monitoring with payback at the same time. They either miss interpret my mail or either does not understand what I am saying here. You however fully comprehend what I am saying. I know about what you are saying about if you ad another track then this would be possible, however if one works with a live bands and or groups with lots of tracks, tracking this becomes a pain to do in this why, as well time consuming to do. If one works with a single track then this would not be of any hassle, however working with several tracks it hampers work flow and slows down momentum. I do not know if the same issue exists in HD; do any care to elaborate on this one?
Is it just LE that works in this why?...............if this is the case Digi please guys implement this for us. The live signal along with playback, along with not only when one hit the record button. This is vital to have live signal for musicians to pick-up there parts along with playback recorded tracks playing; otherwise punch-in becomes tedious and slows down works flow and very time consuming to work with. |
As mentioned this is the way it works and has worked from the first days of audio. the only difrence is that in a classic in line console the engeneer can feed the headphone mix from both the tape send and tape return. still the punch in on a tape machine would act the same as it does in PT.
To do this with PT (LE or HD) you need either 1) A console that can send direct feed to both PT and musicians at the same time plus the recorded feed back to them as well. or 2) It might be possible to emulate this by setting up Aux ins for the mics and sendig them to buses to be recorded on audio track as well as to the headphones. However I typically just duplicate the recorded tracks then delete the audio on the original armed tracks leaving the audio on the duplicate (with possibly trimming the part with the 'bad take'). This only requires 2 clicks and 1 drag with the mouse and gets the job done really fast and is also easy to understand later when editing.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
the way i do it when recording is setup Aux Channels and set their inputs to the instrument or mic channels on the interface used by musicians or vocalists (as many as you need). Their aux channel ouputs are set to the master fader or outputs used for the headphone mixes.
The advantage here is that the musicians can always hear what they are playing. I then create tracks i'm recording to and set their inputs to instruments channels used on the interface. once the tracks are enabled for recording the musicians can play along to recorded tracks and you can punch in whereever needed. |
I use a Digi002 console with a Focusrite pre-amp connected via ADAT to my Digi002, my Digi002 out (L+R) connected to a Samson C-control (control rooms unit) then to my head phone unit. Is there a way to do this besides using an Aux track or is this the only way the getting around this issue?
Usually with other program like Nuendo if you arm record then one receives a live signal along with the monitor button regardless whether there is already a track playing back. The arming and the monitor button of that track allows live monitoring signal which is not determined by a track that has to be played back. |
Input Monitoring | paulrgmusic | Pro Tools 11 | 4 | 06-23-2013 05:50 PM |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
input only monitoring PT8 LE | enough | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-12-2011 03:38 PM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
002 input monitoring | itchybro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-18-2007 07:08 AM |
