Voice
wich is the best solution to adress the voices?
Sorry, I have to improove my English.If i put all channels in auto? |
Re: Voice
I just set it to AUTO.
Re: Voice
I want to know if the auto voice choose the best performance.
Re: Voice
uh, that wood be your job. [img]images/icons/shocked.gif[/img]
Re: Voice
When tracks are assigned to consecutive voices, I've noticed that there is a slight delay between soloing a track in and out. I stick to auto voice assignment unless I'm comping vox....but, that's a different thread.
Re: Voice
Sounds like you have "mute frees assigned voice" checked under the operations menu. With that unchecked, there is absolutely no delay when soloing or muting and unmuting.
Now in response to the original poster's question, I don't think there is a "best solution" when it comes to voicing. In some cases, it's necessary to use assigned voices. In most though, using the default of auto will work fine. It's really a non-factor for 95% of the performance envelope. And when all else fails, test it out yourself. If you're looking for opinions though, I use auto voice for virtually every audio track. Good luck. |
Re: Voice
Thanks a lot.
Re: Voice
Thanks a lot!!!
Making a normal voice into a Cartoon like voice... | meyoik | Post - Surround - Video | 6 | 03-15-2012 05:10 AM |
voice band multitrack instruments and vocals all from voice input for iphone | crizdee | Pro Tools TDM Systems (Mac) | 1 | 01-12-2010 02:56 PM |
Advantage of 16 voice 2 dsp over 16 voice 1 dsp? | flymax | Pro Tools TDM Systems (Mac) | 4 | 02-04-2006 01:10 PM |
Voice weirdness: tracks play wrong voice - any suggestions? | citysoundman | Pro Tools TDM Systems (Mac) | 17 | 10-03-2002 01:45 PM |
voice-over eq | Joe S | Tips & Tricks | 2 | 01-30-2002 10:52 PM |
