Old 01-29-2001, 10:35 AM
rangeroad rangeroad is offline
Default How do I do a proper insert/bus?
This is a silly question, but all I want to do is route my effects rack (2 analog L/R outs, 2 analog L/R ins) and use the effect on a track.
The manual seems a little iffy on this one...any advice appreciated. Thanks.
Old 01-29-2001, 06:18 PM
beau beau is offline
Default Re: How do I do a proper insert/bus?
i am pretty sure that you click on insert. then when it asks you, plug-in or output, select output.
i could be wrong, thats off the top of my head.
beau
Old 01-29-2001, 09:59 PM
Juergen Juergen is offline
Here's a way I would try it:
Let's say you want your piano to go to your reverb, and you got L and R. For those tracks, select as the output something like, 3 and 4 (3 will be L and 4 will be R). In the back of your 001 are 3 and 4 (as you know), you route those to your L and R Input of your fx unit, then route the L and R Output of your fx unit back into 2 of the Inputs of your 001. Then you go to your PT internal mixer and select 2 tracks (aux tracks), choose the proper Inputs (the ones you have your fx unit plugged into). You could also record your fx that way, but you'd have to choose audio tracks instead of aux).
Or is there a better way of doing it that I am not aware of?
Juergen
Old 01-30-2001, 03:53 AM
Ben Jenssen's Avatar
You can also use a track send instead of routing the track output to the external effect. But as far as I know, the only way to gat the return into PT is to set up a aux track (mono or stereo).
Old 01-30-2001, 04:41 AM
djhydro djhydro is offline
consider the latency issue doing that (it's been covered so make a search to learn about it).
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 07:29 AM
Proper HDD ibanfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-09-2009 12:09 PM
Proper Mixdown FullFreq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-16-2004 12:27 AM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
So now THIS is the proper way to BTD??? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-06-2002 04:50 PM
