Old 11-11-2011, 10:20 AM
dstar917 dstar917 is offline
Default Can I use HD9 with any interface directly?
Hi all,
I was thinking about getting protools HD for my 8 core mac pro, and I was wondering which protools HD lets you use any interface for 192, such as Apogee etc. Also, would it be direct firewire? Or would I still have to have a card in my mac of some kind..? If so, which? Thanks for your help in advance!!
Old 11-11-2011, 10:39 AM
Talisker Talisker is offline
Default Re: Can I use HD9 with any interface directly?
Well PT 9 HD comes with avid hardware, that's what makes it HD. If you just get PT 9, it is meant to work with any hardware like any firewire interface.
Mac Mini 205 Ghz Intel Core i5, 16 GB Ram, OSX 10.8.5, Focusrite Saffire Pro 40,Behringer ADA 8200 Pro Tools 10.3.9, 2xGlyph hard drive 750GB
Old 11-11-2011, 11:45 AM
So doing it the way you're saying means that with just PT 9 I can use an interface capable of 192 and record in 192 correct? Like and Apogee Ensemble or Rosetta and only use PT 9 Software? Or would I need some other AVID hardware as well. Just to be clear. Thanks again for your reply.
Old 11-11-2011, 11:51 AM
PT9 by itself only allows for up to 96khz. If you wanna create sessions with 192khz, you need the production toolkit with it (still cheaper than a HD system )
Old 11-11-2011, 12:48 PM
Wait, so if I obtained PT 9 HD software, I would need DV Toolkit to record in 192? Let's put it this way: If I woke up one morning and had a only PT 9 HD software disc and the licensed iLok sitting in my room, what would I need to record at 192 at that point? Hope that clears up any confusion to my question. Thanks again.
Old 11-11-2011, 12:57 PM
No. The DV Toolkit is a dead item and is no longer useful with Pro Tools(never was with HD). If you own PT9 HD(with an iLok asset so the program will run) then you have all the functionality of PT9(non-HD) with the CPTK when run without HD hardware. That means you can install the software on something like a laptop with any of a dozen USB or firewire interfaces and have almost 100% of the power of an HD system(without any TDM plugins). The recording sample rates will be determined by the hardware you use to get audio into and out of the computer.
Old 11-11-2011, 01:09 PM
ok...if this is so, sorry for my wrong info, never knew, you can run HD software without HD Hardware.... it is getting all a bit confusing.
Old 11-11-2011, 01:23 PM
So albee1952, if I had only PT 9 HD software and an Apogee I can record at 192 rate, without some kind of extra AVID sound card for my mac, just firewire, correct?
If so, is that the same with PT 8 HD? or only 9 and higher..? Thanks.
Old 11-11-2011, 07:41 PM
nst7 nst7 is offline
Only 9 and higher.
Old 11-11-2011, 10:04 PM
Originally Posted by nst7 View Post
Only 9 and higher.
That's the ticket Version 9 ended the Digi-only hardware requirement. I would check with Apogee for the most accurate info(I haven't used their stuff yet).
Can we go directly to 10.3.4 from 10.2? Southsidemusic macOS 5 03-22-2013 09:37 PM
USB audio interface works better when plugged in directly rather than through a hub. lkingston Pro Tools M-Powered (Win) 5 06-14-2010 10:21 AM
Mic directly into camera? Soliton Post - Surround - Video 11 04-24-2006 03:31 PM
How do-i get directly here maxserg Pro Tools TDM Systems (Mac) 2 08-20-2003 06:07 PM
How to record directly from the web strangelittleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2003 06:13 PM
