Old 08-17-2004, 01:13 AM
odd odd is offline
Default Turntables directly into 002?
... Why doesn't this work? Do I need something else in the signal chain to make this sound good or are there any good free plug-ins I could use to make them sound adequate? Thanks in advance!
Old 08-17-2004, 01:36 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Turntables directly into 002?
this will require an amp before 002, as turntables don't feed line-level signal.
Janne
Old 08-17-2004, 01:49 AM
odd odd is offline
Another amp??? Arrgghh this is becoming expensive! haha .. Thanks again//.
Old 08-17-2004, 02:43 AM
JFreak's Avatar
or, you can just route the turntable via your home hifi system (if that has line level outputs).
Janne
Old 08-17-2004, 07:37 AM
pk_hat pk_hat is offline
It's just a little phono amp, usually around $30. Little black rectangular box with inputs for your turntables, a pair of RCA outputs and a ground connector. Set up in 2 minutes, plug to your 002R's ALT-SRC and you're done. Works great for me, then I engage the 7/8 switch, select inputs 7-8 in PT or Live when it's time to steal!!!
www.myspace.com/krou
Old 08-17-2004, 10:36 AM
Bezo Bezo is offline
Related question.
I don't have a turntable, but I need to jack some excerpts from a speech off a CD. I figured I'd rip the CD in iTunes, but, how do I import audio from somewhere other than another session? Is this possible?
PTLE 8.0.5, Digi 002 Rack
iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8
Glyph GT050Q Drives
Old 08-17-2004, 10:40 AM
Related question.
um....
Once you have the file from cd saved somewhere, "import audio" form regions list. I'm baffled that this is news to you....
Old 08-17-2004, 10:48 AM
Related question.
um....
I'm aware of the process, just never used it. And I was under the impression that you may only be able to import audio from other sessions. I'm not near the unit to test it out.
I'm assuming that you are saying I can import audio from any where, not just other Pro Tools sessions.
Glyph GT050Q Drives
Old 08-17-2004, 11:47 AM
your assumption is correct.
Old 08-17-2004, 11:56 AM
You also need to have an amp with an RIAA EQ curve found in a turntable phono preamp.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Turntables & Vinyls firsty33 General Discussion 4 10-30-2013 04:46 PM
Recording from turntables to mbox 2 Godballe General Discussion 4 07-07-2010 08:46 AM
Turntables and Protools...HELP???? ProperTonez General Discussion 2 09-18-2006 06:04 PM
M-BOX EXPERTS: Please help me hook-up turntables! williamc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2004 01:30 PM
Recording Turntables Matt Lock General Discussion 2 09-04-2001 12:04 PM
