when will the Protools be 64bit application?
I wonder when will be the protools a 64bit application ? I can't do arrangement with 4gb of ram memory. Also is it possible to run Protools LE and M-powered in the same time on one computer so i can play much more instruments and use 8gb of ram(4 gb per application)??? If this is possible Ill buy a profire light bridge for output expansion??? |
Re: when will the Protools be 64bit application?
probably not until all (80=%) of the XP rigs are replaced by Vista (oh, and Vista needs to work to )
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks I intersting about OS X not Vista. |
Digi will not go to the trouble of double coding
same reason AU will never be supported
protools.exe - application error | tonegiver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-06-2010 10:46 AM |
Protools 64bit | joji | Pro Tools TDM Systems (Mac) | 17 | 02-27-2010 12:59 PM |
Protools 8 and 64bit, When?? We really need this!!!!! | guileman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 06-03-2009 02:56 PM |
When will ProTools LE be a 64-bit application? | floatingpoint_32bit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-11-2006 04:14 PM |
Got a hot Kensington Application Set for ProTools? | David Hempling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-04-2001 12:47 AM |
