Old 10-29-2003, 05:54 PM
Laboratory Laboratory is offline
Default Using outboard gear with 002
I'm trying to figure out how to use my outboard gear with the 002 when mixing. How do I set up the routing. I know I use the outputs on the 002 to send to gear inputs, and then the gear outputs to the 002 inputs, I can't seem to figure out how to set the screen up in protools. Do I use the sends? input, outputs. please help
mark
Old 10-29-2003, 06:05 PM
Default Re: Using outboard gear with 002
YOu patch the outboard gear in where you'd place a plug-in.. but select an I/O set instead (in the insert menu, select I/O).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
ADC with outboard gear? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2010 06:33 PM
Anybody using outboard gear with PT ? Blackers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-08-2010 04:23 PM
Using outboard gear 98wildcat Pro Tools TDM Systems (Mac) 8 09-19-2007 12:54 PM
where to put outboard gear wayner ICON & C|24 0 09-15-2005 06:19 PM
Outboard gear??????????? adspi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-20-2000 02:38 PM
