Silent tracks...Tech Help
I recorded 16 tracks from two ADATs using the ADAT bridge I/O. I can see the waveforms and they are all coloured but there is no sound!! PTv5.0/PIII/256MB/Adaptec 2940U2W/Seagate Cheetah. Any ideas? Thanks in advance. |
Re: Silent tracks...Tech Help
Raven
Do other sessions you have recorded playback? Do you only have (1) interface,( the ADAT Bridge?) Have you tied the demo session from the PT 5.0 CD. Does the transport move, numbers rolling when you try to playback? Please provide more information about your situation. thanks Mj |
Mj,
There is only one ADAT Bridge I/O interface. Other sessions play. Using an O2R with ADAT cards normal sessions are recorded and work is going on. This happened with only one session. In fact three songs were recorded from the Alesis ADAT one after the other. Two songs are playing back. Just this one is behaving odd. Later when I recorded a two track from DAT via S/PDIF, the same problem occured. When I recorded this song again, it played back fine. In this session also the transport is moving. I am realy puzzled as everything seems normal. I have been setting up PT systems on both the platforms for some time now. Thanks [This message has been edited by Raven (edited May 16, 2000).] |
Raven
Can you provide more info: Drive configuration. How many drives including IDE and SCSI, what is the formats on all drives. System, computer make, model and SCSI card? A work around and or test is can you create a new session and "import" the audio from the audio folder of the bad session into the new session and drag the audio into new tracks (spot mode original time stamp) and will the audio play? Will the audio play from the import window? Mj |
9.0.6 - audio tracks sometimes are silent, but no error message | iain_m | Windows | 3 | 08-23-2012 05:08 AM |
Loud noise on file opening - followed by silent tracks | Paxalot | Pro Tools TDM Systems (Mac) | 6 | 12-12-2011 01:24 PM |
Rendering elstic audio tracks = huge silent gaps! | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2009 02:08 PM |
Armed Tracks Go Silent When Other Tracks Play | splatterkep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-01-2009 05:02 PM |
MIDI is suddenly silent silent... possible bug?? | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 08-19-2001 11:08 PM |
